- 0
Voltage drop headlights flicker while in D during hot weather
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 24 Members, 0 Anonymous, 1,864 Guests (See full list)
Question
jgazdag
Hi there, I am trying to sort out some issues with my 08 Silverado crew cab 5.3L. When it's hot outside 90+, my voltage drops to 12ish or below, my headlights flicker rapidly when I am at a light or idle for even a short period of time, it also seems like my AC output gets weaker- not as cold as when actually driving. When its 75 or below, I do not have any issues.
If I put the truck in P the voltage slowly creeps up. When I start the truck it is 14ish and it drops from there as I drive. At highway speeds it builds up enough so that the AC seems normal and my headlights are no longer flickering.
I replaced my battery- positive battery post came out of the battery, and had the system tested. Advance Auto tested everything OK.. the truck was turned off so the battery was back to 14 when it started but it did drop slightly and came back up because the truck was in park. At home I pulled up to park and had my foot on the break and saw the headlights flickering into the garage. As soon as I put it in P, the flickering stopped and the voltage restored. It has completely shut all electrical off before and in the past there was times it wound not start unless I jiggled the positive battery cable..sorry lots of issues recently in the past but I have not been able to isolate anything since they are testing ok, but I don't believe my headlights should flicker and the only thing I see when this is happening is my voltage gauge shows 12ish.
7 answers to this question
