Kolton285
Speedometer reading upwards of 20 mph faster than I'm going.
So, I recently started driving my dad's old 98 Chevy Silverado Z71, and I've noticed the speedometer is reading upwards of 20 mph faster than I'm actually going. He said that he accidentally pressed the 4 Lo switch one time without following the proper procedure and ever since then it has been off. Can the four low gear actually mess up the speedometer or is something else wrong? And how would I fix it?
Share this post
Link to post
Give a search for vss buffer for the truck, sometimes unplugging it for a bit helps
Share this post
Link to post
Would unplugging the battery achieve the same affect?
Share this post
Link to post
Good question,not sure,try it,I just remember from threads in the past,that,that was the recommendation,it is the speedo corrector for 4lo
Share this post
Link to post
Tried it, no dice. It's a troubling issue, the cruise control works fine and the speedo is at least somewhat indicative of the truck's speed, ergo no bouncing or twitching like you'd see with a bad speed sensor, and I tried removing the battery and disconnecting the vss buffer. Could my cluster be out of wack? Really hoping it's not the case, cuz those things are expensive to replace and reprogram. Any additional help would be greatly appreciated.
Share this post
Link to post
1 hour ago, Brian Lindsey said:
not really , i think they do complete  rebuild  for 80. to 125 ,  or you could get one off ebay , or a junkyard near you
I'll keep that in mind if it comes down to it, still not positive if the fault is in the cluster though. Thanks for the tip.
Share this post
Link to post
  • Similar Content
    • By mark97213
      Greetings all.  Looking for some advice on why I might keep blowing speedometer transducers.  I've gone through two replacements and although they work fine for about 30 minutes, they eventually just stop and the speedometer fails.  Any idea what would cause the transducers' to keep failing? Rebuilt transmission with new speedometer plastic gear in transmission.  I'm at a loss.
    • By whoy2002
      Hi, I recently pulled my t-case and replaced the housing on it due to the pump rub issue. After re-installing everything was fine for about  1 mile then the abs  light came on  and I got  "service brakes  " message and my speedo quit working,  which also causes my trans to shift hard and erradictly . Long story short.... I've checked all the fuses , replaced the speed senor in the t-case (as far as I know this is the only one the truck has , it's a base work truck trim) and the wiring harness to the t -case and speed sensor, and no dice.  The only codes that it is showing on the reader at the local Oreilly's  is mass airflow and knock sensor.   4x4 still engages fine, the motor in the front axle works too.         Btw,  It's a 2003 2500hd 4x4  6.0 Silverado  base work truck.    If anyone has any info on this matter that  could help   I would sure appreciate it  ,  thanks.
          Quote   Edit
    • By whoy2002
    • By Brady Gatorz
      Hello I just purchased a 2018 Silverado 1500 with the “custom trim”. I was curious to know if anyone has..or it can be done. I want to put the Denali gauges out of a 2018 Denali in Silverado. Because I do not have steering controls on my current steering. Thank you for helping out👍
    • By US Dashworks
      We are proud to announce the "GT" line of gauge faces. you can order them now, check out   https://usdashworks.com/product/style-gt/  to check them out and place your order.
    No registered users viewing this page.
    MacAaroni
    MacAaroni
  • Who's Online   22 Members, 0 Anonymous, 830 Guests (See full list)
