Davidj98
GM 2" lift install DIY
I plan to buy this lift and either install myself or throw my keys to the dealer.  Someone posted install instructions (thanks!) and it looks pretty straight forward. I'll save about $500 bucks if I DIY.
My question is has anyone installed this lift themselves and then went to dealer for calibration and alignment?  I'd love to hear from you.
thanks!
Share this post
Link to post
Google the PN, instructions can be found.
Share this post
Link to post
I received the GM lift kit today, plan to install tomorrow, I'll keep ya updated.  I have an appointment with dealer to install software and alignment Monday.
Edited by Davidj98
Share this post
Link to post
I have the pdf install instructions, PM me your email
Share this post
Link to post
Good luck, had the dealer install mine before I purchased the truck
Ryan B.
Share this post
Link to post
Who much was it? Prices are all over the place on this kit.
Share this post
Link to post
I ended getting the best deal on eBay at $1079.99 , seller was billcramergm
Share this post
Link to post
I finished install this weekend, at dealer now getting alignment and software install for camera and steering. Install went well, hardest part was compressing spring. I bought the McPherson tool from harbor freight which had just enough thread to compress springs. I was able to move much quicker on passenger side after learning on drivers side. I did break the end link to sway bar, don’t use an impact on that one!
I was surprised how detailed directions were, you really can’t screw this up, it even stated to use only hand tools on tie rod, upper A arm and end link! :)
rear was very easy!
Share this post
Link to post
rear was very easy!
For spring compressing, I ended up buying one of these clamshell style tools: https://www.amazon.com/OTC-6494-Clamshell-Spring-Compressor/dp/B0002SRHU6 It's a beast, and you can use an impact to do the spring compression.  HF has one as well (called Single Action Strut Spring Compressor).
Share this post
Link to post
Yeah I prefer that style to just don’t use one very often, so bought on a budget
Share this post
Link to post
on the instructions is a number you need also on shipping box is a seriel number  I did mine upgrade took less than a 1/2 hour to flash it I alos used a roughcountry leveling kit with factory 18" rims I went from ground/top of wheel well front 37 1/4 to 40 inch
Share this post
Link to post
