Sign in to follow this
Ken Petersen
The alarm went off and I started pushing buttons on the fob now it won’t start?
So I was getting ready to move my 2011 Serria with a 6.0 and apparently I pushed the panic button as I pulled the keys out of my pocket.  The horn started beeping and I reacted by pushing the other two options on the fob before I put the key in the ignition and the horn quit.
Now I put the key into the ignition and try to start it, it spins the engine and when I let go of the key the engine continues to spin for a few seconds, no start just spins the engine the same way every time I try it.  I even tried to reset the passlock using the recommended process that takes 30 minuets,
Anyone have any ideas??
Share this post
Link to post
matter of interest did you disconnect the battery for say 5 minutes, did you do anything else at all when you opened the door and tried to start it, my starter stops turning when I stop turning the key or was you talking about it making the noise as if it released from the flywheel.
You might try checking the fuses I remove a fuse when I leave my truck for any length of time and all that would happen is the engine turns without starting.
Share this post
Link to post
