Cleaned fronts side of throttle body (didn't remove) as best I could.
Scanner was telling me cylinder 2 and 8 misfire, with code p0135, swapped o2 sensors (bank 1) misfire switched to 7 and 8 cylinders. Still p0135 error on scanner, checked wiring on 02 sensors that I could see, no apparent damage
Misfire's only at idle, when I apply gas misfire's go away
Read on the net, could be idle air valve (can you clean that, rivited to throttle body, shoot cleaner in that tiny hole?), maf sensor (cleaned that) all little wires good, no apparent vacuum leaks
Disconnected battery to try to reset iac valve, no change...
Question
LEG
2003 yukon xl 1500
Replaced: plugs, wires, injectors, fuel filter, fuel pump.
Re-tested: coils, wires
What am I missing?
16 answers to this question
