Brighter HID bulbs for base headlights in 2017 Silverado/Sierra 1500
Hi guys, so I'd like some more light put out of my factory headlight assemblies. My truck has the factory HIDs, but they don't seem that bright, and they never have. Is there an aftermarket bulb that works in the stock headlight housing with a higher LUX?
I have had these for 2+ years and love them. Made quiet a big difference in my opinion. Expensive but have been worth it. In the pic, left is OEM, right is morimoto.
https://www.theretrofitsource.com/d5s-morimoto-xb-hid.html?carDisplay=2017+Chevrolet+Silverado+1500+%28HID+Equipped%29&preselect=&preselect_restrict=1009a75dac92812dd8e26bdabbb991a63.jpg
Second that, did the upgrade on my 15 2500 and 16 yukon high/lows/fogs
36 minutes ago, DominatorZ71 said:
If you're looking for the best option I'd say a set of Hylux 35w bulbs and ballasts. Morimoto is very expensive for some very mixed reviews, some reporting losing their auto lights. My info is based on research I've done the last few weeks and my conclusion is going to be a complete retrofit
I just googled them. From what I read they're just plug and play correct? No splicing or cutting? If so that's what I'm going with... Also by auto lights, do you mean how they come on automatic at night?
I originally had the kit from TRS with Morimoto ballasts, igniters and bulbs. In the 2 years I’ve had the kit, I’ve changed out several ballasts and igniters. I recently had them change from the morimoto to the Hylux ballast/igniter combo on a warranty claim. I did this based on reviews and my own research on longevity. I even purchased a spare ballast and bulb for any future issues so I’m not without lights. So far I’ve been very pleased. I even got my father in law to upgrade his factory lights on his 14 Sierra this past weekend. If you order them from TRS, order the relay harness, anti flicker capacitor, bulbs, and the hylux ballasts. It super easy to install and I’m sure you’ll be pleased with the results.
Yes on both. They are plug and play and I'm not sure about the Hyluxs but the Morimotos for sure will make Auto headlights (at night and tunnels) not work properly.
On our trucks it's all in one which makes it more expensive and less options. In order to keep the dust cover you have to stick to plug in play options. They're called D5s bulbs
Hylux it is then! [emoji6][emoji106] I'll keep everyone posted, probably won't get them for a couple months. Canadian exchange rate sucks. Thanks for your help bud!
Something to mention: make sure you do these if you don't want any cutting or splicing:
https://hidkitpros.com/shop/hylux-d5s-oe-headlight-xenon-hid-bulbs/
Doesn't have to be that site but they do another set that requires cutting into the dust cap that allows for even brighter options but modifying the dust cap.
https://www.distantxtremes.com/store/p1164/D5S-Hylux-HID-Upgrade-System.html#/
An install video is also available with that one if needed
Interesting, I followed your link and it seems different to the ones I found. They all have a slightly different Kelvin rating. The inconsistency between the three links has me concerned, I tried to find a Hylux website but the only site I found only had ballasts. Are you sure these aren't some obscure cheap Chinese manufacture? Anyone have them that can confirm where they're made?
I should add that I wouldn't go with the style that requires cutting the dust caps.
Your link: https://hidkitpros.com/shop/hylux-d5s-oe-headlight-xenon-hid-bulbs/
Link 1 I found: https://esskcustoms.com/products/d5s-hylux-hid?variant=20327372292184&currency=CAD&utm_campaign=gs-2019-07-22
Link 2 I found: https://www.prolightz.com/hylux-d5s-hid-bulbs.html
I’m not sure how the new model lights are but the 14 and 15’s I’ve worked on have the dust covers for the back of the headlight housing. I just used a 1” step drill to drill a hole into the cover and the the helmet included with the bulb fit snug.
Link 2 is the one. I can't open link one for some reason. And realistically all ballasts come from China but Hylux is a very reputable brand like Morimoto
 Share
