Sign up for FREE! Become a GM-Trucks.com Member Today!
Sign in to follow this
Followers
Similar Content
By JRTJ54
Hello. I’m new to this so any help would be appreciated. I have a 2019 Silverado Custom Trail Boss. I recently saw someone on social media who upgraded the entire interior of their Custom Trail Boss with High Country interior. My main question is about how I go about putting a new High Country cluster in my custom trail boss. I’ll also need the upgraded steering wheel with the buttons on the right side to toggle through the screen. Do I need to get it programmed to work? If so, where can I get that done? Any information on this topic will help me a lot because I can’t seem to find much information anywhere on the internet. Thank you very much for your time. I appreciate your input.
By fondupot
So I wanted a power locking tailgate on my 2019 GMC Canyon. In the past I have used Pop n Lock, but that eventually failed after about 2 years. So Instead, I started looking into how I could retrofit a 2020 power locking handle into my 2019.
The video below details everything you need to do it yourself. Totally worth the effort. The OEM lock is much nicer, quieter and will "fingers crossed" last longer than two years.
By Isaac Riffel
Hey there! I'm going to do a public service to the GM Truck people and make a guide on how to remove your front fenders from your Early 00's Silverado, Sierra, Yukon, Suburban, Yukon XL, and Tahoe. It's pretty straight forward, but this guide should be a help anyway.
If you would prefer to watch an in-depth video with the same steps I'm showing here, please click this link --------> Fender Removal Video
1. Here are the tools you will need:
13 MM Socket 10 MM Socket 13 MM Wrench 10 MM Wrench Socket Wrench Socket Extensions Penetrating Oil or WD-40 Bungee Cord(s) Patience
Let's first go over why I'm doing this, this truck was donated to me and my father as a project and this fender has a nasty rust hole straight through. So, we're hitting the Pick-N-Pull tomorrow to get a new fender.
(Remove your wheel(s) before this guide)
2. Remove the hood hinge (13MM Bolt), or the hood itself. We had a way to support the side of the hood we were removing so we did not need to entirely remove the hood. If you do not have a way to support the hood, you will need to remove the whole thing.
3. Remove all the 13mm's along the fender you are wanting to remove
4. Remove wheel well splash cover by pulling the head of the little clips to free the liner, here is what the clips look like:
5. Soak 13 MM bolt where the fender and rocker panel meet with lube then try and break it loose. (These are exposed so it'll be rusty.)
6. Remove the 2 hidden 13 MM bolts in the door jam, use a long extension.
7. Unscrew Airbox and remove the hose, next remove your air filter and the top of the airbox.
8. Release bottom part of the airbox by using a screwdriver to push the little pins down which will pop the box out.
9. Remove the 3 10MM bolts holding the airbox support down. Remove any remaining clips.
10. Loosen coolant reservoir and secure to the side
https://imgur.com/gallery/jO3RCUZ
11. Remove all remaining 13 mm and 10 mm bolts holding fender to chassis.
12. Remove headlight by pulling up on the metal bars, removing them. Next, pull the light and disconnect the connectors.
13. Remove grill clip from fender
14. Remove the last bolt holding the hood hinge to the fender with a wrench
15. Remove 13 MM bolt holding fender in the wheel well (inner bumper)
17. Wiggle fender upward and pull, it should easily come off of the truck.
Ta-Da! Now you have tons of access to work or you're halfway done replacing your fender. I hope this helps!
If you have trouble, please comment or refer to this video: Thanks!
By Rado5.319
This diode installation allows all of the lights to remain on simultaneously when the high beams are activated on GM vehicles. The diode is super easy to install, you need $2 and 10 minutes. 9 of those minutes will be spent congratulating yourself.After diode placement your lights will function as follows:
In auto mode- whenever your lights come on automatically the fogs will be on also. Low Beams & Fogs- Only Low Beams & Fogs will be on High Beams- Low Beams, Fog Lights, & High Beams will all be on (normally by default) The vehicle turns off the fogs when in high beam mode, but this diode solves that. MAKE SURE THE SIDE OF THE DIODE WITHOUT THE STRIPE IS IN THE 10 PIN. The diode allows electricity to travel in only one direction.
By Jonathan Floyd
Recently purchased 3.0 JLT oil catch can. As I went to install it on my Silverado I honestly didn’t really see if it would fit so I backed off to get more info. Has anyone installed a oil catch can on the 2019 Silverado? The main reason for stopping the install was that the intake has some piece on the left holding it together that i can’t seem to find a way to get loose. I loosened the clamps to the air box and Intake manifold but some weird peice on the left is still holding it together when i attempted to take the intake off.
Recently Browsing 0 members
No registered users viewing this page.
Total Topics2,450,694
Who's Online 74 Members, 1 Anonymous, 3,527 Guests (See full list)
- SilverMachine
- zamoramax
- kickass audio
- Ruggedly
- HoosierZ
- success
- OnTheReel
- Rozz522
- dkloud216
- waterman
- Brooks Blake
- blue_bullet
- SILVER SLED
- Graytidefan
- Wormydog1724
- gtodoc
- dcad
- slumpychuck
- YYC-SIERRA
- txdox21
- 18LT
- GreatWhiteMexican
- 19trax95
- David Withrow
- Tanner Smith
- 7milesout
- lsufan1971
- Luke Millard
- ullose272
- olddutchfarm
- Cheef16
- Gilisfloyd
- psu
- Dock Rocker
- Weir003
- bkccorp
- KARNUT
- rtownsend
- extski
- WTAdventurze
- jstenger
- sampearson
- DmaxHugh
- Brokeass101
- turboolds77
- kevin79
- f8l vnm
- Heysoos223
- Frankielozano214
- 02DenaliBaby
- mmatthews84
- mark_kershner
- navaidone
- rascalmafia
- eddiescott10000
- rickmc17
- dennismc
- lonestardiver
- Offroadman00
- Nalby
- garagerog
- lonecountryboy
- Tmiller
- Chris2087
- smurfy71
- ammoaddict
- DeePa
- [email protected]
- Cupton
- savage99
- TexasRedNeck
- Doug in AB
- ericarenee
- rev44
