- 0
2015 2500HD Horn Inop
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 24 Members, 2 Anonymous, 1,760 Guests (See full list)
Question
kevin_nj
I've had an intermittent inoperative horn issue for a couple of years now. Horn has been replaced & I cleaned the ground at the frame by the horn. When it fails, it fails from steering wheel switch and key fob, that is one way I know it is not the steering wheel switch/clockspring.
The last time it failed (this past summer), I had an extra pair of hands to help diagnose. We used jumper cables to go from the ground connection at the frame directly to the battery to rule out a bad ground. We discovered we could here the relay clicking in the fuse box located driver side in the engine bay. I wiggled the box and the two large locking connectors nearby and the horn began working again. Periodic testing since that had no failures, until today. Out of ~10 attempts the horn only sounded 3 times. Wiggling the fuse box and nearby connections again did not resolve the failure this time.
I've attempted to remove the fuse box and the connectors to re-seat, but they do not want to release. I'm concerned with breaking something if I force too hard. What is the trick to re-seat these connections?
Is there agreement that I'm on the right track of a bad connection in the area? Since I can hear the relay click, that (to me) rules out the BCM and wiring upstream and leaves me with the connections/wiring leaving the fuse/relay box.
8 answers to this question
