Sign up for FREE! Become a GM-Trucks.com Member Today!
Torsen differential upgrade in a 97 c1500
Similar Content
By SHEVLINI
Anyone updated a 2016 Sierra to 2020 Sierra (Bose 7 speaker on both?) I am looking to update my 2016 SLT crew to a 2020 Denali, and want to confirm I am dealing with the same (or similar) animal. The 2016 has PAC AP4-GM61, old school PPI PC450 running 100x4 at 2 ohm, Infinity Kappa 60CSX component front, 62IX 2 way rear, Rockford Fosgate R500X1D running 500 watts at 2 ohms, and a sealed JL 10w1v3-4. Embarrassed to say factory dash speakers, but you do not hear them except for a phone call... Incredible sounding system, but I do not want to have to do it again. Does 2020+ no longer use "MOST" bus communication? Anyone measure wattage from Bose? Any difference between SLT, AT4, and Denali Bose amps? Thanks in advance for your research assistance.
By Cohen
Looking for what else you guys recommend to replace. I Noticed one of my tie rod grease boots was busted, planning to replace both inner and outer tie rods, sway bay end link, sway bar bushings.
Anything else while I’m under there and have to get an alignment? Mileage is at 78,000 miles.
Looking to use MOOG parts. Running 33’s so if anyone else has upgraded to something beefier let me know!
By Nathan m
I have a 09 silverado 1500 WT
It has heated rear window but no heated mirrors. And I can't see a wire for heated mirrors in the door compartment (although I haven't opened the door panels in a few months) I do seem to have 2 wires (it feels like 2) going through the door boot (I haven't opened the boot to see the colors but I assume it is for the door open sensor, but I could be wrong)
I am wanting to add tow mirrors to the truck and especially heated mirrors ( I plow with the truck and really would love the heated mirrors) I was wondering how I would go about adding heated mirrors ( like I said I have the heated back glass so shouldn't the wiring for heated mirrors already be in the truck as I think they run off the same switch and I'm gonna assume the same harness ( I could be completely wrong and they could be different harnesses)
Looking for help as I am wanting to do this conversion if possible
By cprime
My 2018 GMC sierra has a 150 watt inviter. I've hear the newer trucks with the plug in the cab and the box have 400 watt inverters. Anyone try to upgrade or retrofit these inverters into an older truck? I'm looking for a little more power and so far this is how I want to go about it instead of installing a separate inverter.
By Lucas Kveum
Currently I have a stock 2010 chevy 2500HD and I'm thinking about getting aftermarket wheels. Im looking at a set of 18x9 wheels with a +12 offset, I have a set of 265/70/18 tires laying around, will I have any rubbing issues with this setup
Recently Browsing 0 members
242k
Total Topics1.4m
Who's Online 34 Members, 0 Anonymous, 1,093 Guests (See full list)
- Gangly
- SoundsGoodStereo
- Matt Robertson
- Workdog
- Lamar Gunter
- KDVL3269
- Hector Charre
- Solo3937
- nards444
- Driggs
- KARNUT
- e.texerado
- Chevy-down-south
- Snowcamo
- Sam Martello
- BumpStop97
- C/K Man
- OliverDennis52
- mikeyk101
- Shay Cast
- Ry Guy
- junlin
- Random
- S-Taylor
- Manuel Espino
- Flatus
- Bikerjon
- k2112c
- Kenneth Branch
- Tim Slavens
- eppieguy
- KOLDUS2023RST
- Elite130
- slj2008
