Michael Ruch Posted May 31, 2020 Share Posted May 31, 2020 (edited) Customer complaint - flashing check engine light under light throttle check engine light flashes for roughly 10 seconds. 2020 Chevy Silverado 1500 5.3 10 spd bone stock has 3800 miles on it first time bringing it in they pulled the codes and said that you have a p0300 random misfire 28 counts on cylinder 8. Cleared codes and moved on. Drive the truck 200 miles and light comes on again (flashing). pull codes and have p0300 again cylinder 8 120 counts. Ill attach pictures of the freeze frame data. Seams to run good only complaint is chugging under light throttle when going 40-60 range Very upset about this. Edited May 31, 2020 by Michael Ruch Quote Link to comment Share on other sites More sharing options...
1997SierraSLT Posted May 31, 2020 Share Posted May 31, 2020 Welcome to GM ownership. Get used to P0300 because you'll be seeing that flashing CEL for years to come. 1 Quote Link to comment Share on other sites More sharing options...
Michael Ruch Posted May 31, 2020 Author Share Posted May 31, 2020 13 minutes ago, 1997SierraSLT said: Welcome to GM ownership. Get used to P0300 because you'll be seeing that flashing CEL for years to come. Is this a common problem? I wonder if they are working on a fix. I wonder if it truly is misfiring or just a soft ware problem Quote Link to comment Share on other sites More sharing options...
Sector7500 Posted August 2, 2020 Share Posted August 2, 2020 I am wondering if you have had any solution or update to this issue. I may be having the same problem over the past few days. Flashing check engine light for 10 seconds or so, no noticeable issue. Dealer found store misfire code. Happened again a few days later. Quote Link to comment Share on other sites More sharing options...
Pinnacle Posted August 3, 2020 Share Posted August 3, 2020 On 5/30/2020 at 8:55 PM, 1997SierraSLT said: Welcome to GM ownership. Get used to P0300 because you'll be seeing that flashing CEL for years to come. This is all I need to see to tell me youve been around GM for along time lol Quote Link to comment Share on other sites More sharing options...
SierraNoob Posted August 9, 2020 Share Posted August 9, 2020 Hopefully I'm done dealing with this problem for awhile but mine just had to have a dfm solenoid replaced and I've been battling this issue since 800 miles and I'm at 4300 now. Quote Link to comment Share on other sites More sharing options...
Sector7500 Posted August 10, 2020 Share Posted August 10, 2020 On 8/9/2020 at 4:51 AM, SierraNoob said: Hopefully I'm done dealing with this problem for awhile but mine just had to have a dfm solenoid replaced and I've been battling this issue since 800 miles and I'm at 4300 now. May I ask how it was determined that a DFM solenoid was at fault? The dealers I have brought it to are a bunch of code resetters and "unable to duplicate." No real effort. Quote Link to comment Share on other sites More sharing options...
SierraNoob Posted August 10, 2020 Share Posted August 10, 2020 Sector, I opened a case with gm because I had other issues but after the 2nd time I brought it in for the mifire and they couldn't replicate it they opened a case with gm and got help from their support. First time after that they had it for a week and they couldn't duplicate it and the second time I brought it in a couple days after that gm support told them what to replace I guess. Quote Link to comment Share on other sites More sharing options...
kmeleon Posted February 24, 2021 Share Posted February 24, 2021 Bump to shed more light on these misfire issues. Multiple threads in these forums. Quote Link to comment Share on other sites More sharing options...
