The front passenger caliper is not releasing pressure on the line.  All new front steel lines, rubber lines and passenger caliper.  The abs light is on but not codes come up on the computer. if i crack the line between the rubber and steel line, the caliper releases. the other 3 calipers work as they should.  would the abs module be failing?
Link to post
