tonto340 Posted June 24, 2021 Share Posted June 24, 2021 Does anyone know if GM trailer tire sensors 84338125 and 84152501 work the same? The 84338125 are half the price. Quote Link to comment Share on other sites More sharing options...
CXXX Posted June 25, 2021 Share Posted June 25, 2021 Not sure, but i noticed on the trailering screen the trailer sensors read both tire pressure and TEMPERATURE. Mine is a 2021 Sierra. Quote Link to comment Share on other sites More sharing options...
Josef Posted June 25, 2021 Share Posted June 25, 2021 6 hours ago, tonto340 said: Does anyone know if GM trailer tire sensors 84338125 and 84152501 work the same? The 84338125 are half the price. I have zero idea but maybe it’s two valves instead of 4 in case you have a single axel trailer. Quote Link to comment Share on other sites More sharing options...
redwngr Posted June 25, 2021 Share Posted June 25, 2021 Sensors they sell for vehicle look different than the trailer ones, and are much cheaper. Trailer sensors transmit both pressure and temperature. I'd guess the vehicle ones don't. Trailer sensors are much cheaper if added to a factory order -- but they will only let a set of 4 be purchased with factory order. Trailer app can read 6 at once. Trailer app can be taught the sensors (and other trailer info) for multiple trailers. Hook up the trailer and pick the desired one from the list of those that have been set up (or select guest) Quote Link to comment Share on other sites More sharing options...
Ianf Posted June 26, 2021 Share Posted June 26, 2021 12 hours ago, redwngr said: Trailer sensors transmit both pressure and temperature. I'd guess the vehicle ones don't. All sensors can transmit temperature as well as pressure and battery life estimate. GM just does not use that info for your vehicle tires. Quote Link to comment Share on other sites More sharing options...
redwngr Posted June 26, 2021 Share Posted June 26, 2021 (edited) 2 hours ago, Ianf said: All sensors can transmit temperature as well as pressure and battery life estimate. GM just does not use that info for your vehicle tires. So can the ones the sell for the vehicle be paired with the trailer tire monitor module? (maybe someone with a second set of sensor equipped tires (winter tires?) can see if the ttpms system can pair with them) Edited June 26, 2021 by redwngr Quote Link to comment Share on other sites More sharing options...
AlaskaErik Posted June 27, 2021 Share Posted June 27, 2021 On 6/26/2021 at 6:00 AM, redwngr said: So can the ones the sell for the vehicle be paired with the trailer tire monitor module? (maybe someone with a second set of sensor equipped tires (winter tires?) can see if the ttpms system can pair with them) No. The trailer TPMS sensor is totally different from the one in the truck's tires. Quote Link to comment Share on other sites More sharing options...
