How to remove reflector in Headlamp assemblies
I've noticed that many people have removed the reflector from the headlamp and signal assemblies, but i'm wondering how. I tried pry apart the headlight unit but nearly busted it to pieces around the edges. Can anyone recommend a proper way to do this and if i open them up, what kind of sealent I need to reseal them.
Thanks,
Nathan :confused:
  • 2 months later...
When I removed my amber lenses from my headlights, I also had one hell of a time. The adhesive the held the front and back together is stronger than whale's breath. I just had to go VERY slow and take my time. It took me over two hours to pry the two lenses apart without breaking them. I just used two wide blade screwdrivers and worked it slowly. I resealed the two pieces with a liberal amount of clear silicone. Hope this helps. :thumbs:
good info :cheers: But I tried it with my signals and it did not work i got them apart and found out the reflector is glued into the lense part. so i have to buy the clear corners. worth a try though :cool:
