Tyler Breazeale Posted September 22, 2021 Share Posted September 22, 2021 I’m missing all 3 of these bolts that hold the filler neck to the housing. I’m hoping someone could either give me a part number or somewhere that I could buy some. Thanks Quote Link to comment Share on other sites More sharing options...
txab Posted September 22, 2021 Share Posted September 22, 2021 Go to a hardware store and find some of the correct size. Lowes probably has them in their specialty hardware bins 1 Quote Link to comment Share on other sites More sharing options...
txab Posted September 22, 2021 Share Posted September 22, 2021 (edited) Newdude posted this in the other thread you posted in. You should be able to source them or equivalent locally with no issue Edited September 22, 2021 by txab 2 Quote Link to comment Share on other sites More sharing options...
Ravenkeeper Posted October 27, 2021 Share Posted October 27, 2021 The closest I ever came to this issue is pictured below. This happened to both my (late) '15 and my (current) '18 trucks, oddly, about 3 years into owning either one. This happened when I went to refuel my truck. It will "lock back in," but it will pop again on the next refuel. Went to the nearest hardware store, purchased a bolt, a washer, and a nut. I may take it apart and put some black RTV (or something similar) between the bolt head and the flange, and then paint the bolt head with my touchup pin. The one on my '15 started corroding after about a year. Quote Link to comment Share on other sites More sharing options...
JasonAnderson Posted August 25, 2023 Share Posted August 25, 2023 (edited) Ah, the saga of the missing bolts – it's like they have a secret plan to play hide and seek, don't they? I can totally relate to your situation. There's nothing more frustrating than needing a simple piece to get things rolling again. So, here's a little tip from me to you: check out https://www.scrooz.com.au/. They're like the ultimate bolt and screw specialists, and I've personally used their services to save the day in my own DIY adventures. Trust me, they've got a bolt for every situation! Hope this helps you track down those elusive filler neck bolts and get your fuel tank back in action. Edited August 28, 2023 by JasonAnderson Quote Link to comment Share on other sites More sharing options...
