Running Rich after L96 Swap
I have a 2011 1500 ECSB that I swapped the stock LC9 5.3 for a newer L96 6.0. The tune is stock except for disabling AFM. The truck starts, idles, shifts, and runs fine but I have three recurring codes:
P0106 Manifold Absolute Pressure/BARO Sensor Range/Performance
P0175 System Too Rich (Bank 2)
C0561-71 Actuator Stuck
I'm assuming the third code is because stabilitrak is disabled from the first two codes. I haven't found any vacuum or exhaust leaks yet. Long term fuel trims are around -25%. MAP data seems to look OK although the ECM thinks it is out of range. Does anything stand out in the attached log file, or are there any other parameters I should log to track this down?
1GCR7182_20211001_2.hpl
