Jethro71 Posted October 13, 2021 Share Posted October 13, 2021 I have been using a Pulsar LT since I bought my GMC AT4 6.2L back in May. When I installed the the Pulsar LT, I just velcroed it on top of my stock airbox where it has been just fine. However, recently I added a S&B CAI. Now I can't decide on the best way and place to mount the Pulsar LT. I currently have it zip tied to the intake tube, but I don't really like it there. Does anyone else have both a Pulsar LT and a S&B CAI? Where did you mount the Pulsar LT? Quote Link to comment Share on other sites More sharing options...
Seagate Life Posted October 14, 2021 Share Posted October 14, 2021 You can actually velcro it to the corner support behind the headlight. They now include a bracket that positions the "loose" OBD2 connector in a pretty good location....you might need to chase that down. Here is a quick video on the install I just did. Quote Link to comment Share on other sites More sharing options...
Luke Ouellet Posted October 27, 2021 Share Posted October 27, 2021 Hey there - just installed my S&B last night and did my Pulsar last week knowing I was going eventually get my S&B. I routed the Pulsar wire under the cross brace and used some VHB locking velco on my Pulsar and its quite rugged and clean. Use a couple zip ties to keep things clear from coolant lines and you are set. The bracket that comes with the pulsar can still be placed on the stud bolt BEFORE you put the S&B air box in your truck. Then use the flange nut to secure the airbox and bracket together. This should make sense when you go to install them. Hope this helps! Quote Link to comment Share on other sites More sharing options...
