275/60r20 Mickey Thompson Baja Boss AT
I have a stock 2017 GMC Sierra 1500 slt preferred package. Time to get new tires and the Mickey Thompson Baja boss at’s look promising. Can anybody tell me if the 275/60 will fit without a level and and real world reviews on these tires (particularly road noise)? It shows that they measure at a 33.4 which is a little bigger than other 275/60s. Pics also appreciated
Edited by JLock
 Share
  • Similar Content
    • By Tay2610
      I'm wanting to upgrade my wheel and tire's on my 2022 Silverado Z71 Duramax. I've given it some thought and I don't want to go much beyond what's been factory options (33's). My stock tire's are the 275/60R20's. I've settled on these two tire sizes for the time being and would like some input from the community. The 305/65R18 does seem to be flirting with control arm clearance as I've read that my stock setup may even come into conflict with certain aftermarket UCA's (Camburg billet). I've attached some screen shots of an offset calculator that I've been using for comparisons.
      The aftermarket wheels I'm looking at for this setup do have less positive offset and there for the tire is less than a 1/4" closer to the UCA. I've measured my stock setup and it seems as though this would work as I currently seem to have at least a 1/2" to 3/4". Maybe my bigger concern is the added 1" added outside? I would like to retain the factory mudflaps and wheel well liner. Any experience with running this setup or information about clearance's would be helpful. I've also thought about running a 17" wheel as I really like the look of tall sidewalls. My other thought is to run a 285/75R17 on a 17" rim with a 0 offset. This would definitely help with any potential control arm issue's but it would cause the tire to stick out about 1 1/4" from stock sizing. Would this cause any clearance issue's? This may be my preferred combo, due to the taller sidewall and plenty of control arm clearance.
      Any input is appreciated. I do plan on leveling the truck. My current thought is 5100's or Fox2.0 IFP. Do I need to know anything about these working on a Duramax? Thanks for your time.
      PS...I've attached a screen shot of the two tire sizes in question as compared to one another. I would also be able to run the tires I’m wanting with a “C” load rating at 305/65 vs an “E” rating on the 285’s. Would this be helpful with dampening the harsher ride from the 5100’s?
    • By Thomas Rodriguez
      Hi All,
      Hopefully I placed this in the correct sub-forum...
      I am due to replace my tires on my 2019 Sierra 1500 Denali with the stock 22" wheels. This means the tire size is 275/50/R22 which really limits tire availability. I have considered goin with a 285/45/R22 as that opens up more options. It is 2.1% shorter so hoping it's not going to be an issue with the speedo and mileage staying pretty close to accurate? Thoughts on that tire size? Thoughts? Concerns? How much is this really affecting my annual mileage if we say 10k miles per year? I suspect warranty company is fine with it as my mileage will add up a little faster... Any other tire sizes you guys recommend that open up options that wont require any recalibration to speedo?
      In any case, I live in MN and we have a lot of snowy road days and we ice fish, etc. Using the stock tires on the lake this year was.... well... not good. I got stuck. I would like something that will perform better on snow but also not be real noisy. I have a Denali truck with no real mods because I have finally reached an age where all I want to hear in my truck is my music and nothing else lol. So road noise is a huge factor. I had a Trail Boss as a loaner for the weekend and the aggressive tire profile on those were AWFUL. But the standard all-season tire on a truck that is the same for a car just isn't it. Is there a good all-terrain tire than is quite? Does that even exist? Looking for any input and experience any of you have on the matter.
      Also considering the Continental Terrain Contact A/T as well. Reviews seem to indicate they are very quiet on road as well. These are also a 285/45/R22 (smaller diamter/circumfrence). can changing from a 50 to a 45 series tire affect road noise and comfort a lot? I had 24s on an Escalade running 30 or 35 series tires and they didn't seem to sacrifice comfort, but its been a while.
    • By Hunter Carter
      I have a 2018 Silverado 1500 LTZ Z71 with 2” leveling kit I currently have 265/65R18 tires. I want to go bigger but also keep stock wheels. I want a big size but something that won’t rub anywhere I’ve thought about a 275/70R18 but want some other peoples thoughts?
    • By Austin Poff
      Hey guys! New to the forum here. Previously had a Tacoma and switched to a 1500.
      Wanting to do a 5” lift on my 2020 LT and thinking about doing 33.5s on 12x10s. Does anyone have any pics here I could see that are similar? Looking at 275/60/r20s
      thanks all!
    • By Mitchell Jackson
      Wanting to get bigger tires on my truck, installing a lift kit as well.
      Can I stretch 285/55/r20's on 20x12 rims with -44 offset?
      Has anyone does this?
      Also will this effect my tire life any reviews would be awesome.
      (Leveling kit recommendations would be awesome as well)
    242k
    1.4m
    musilife
    musilife
