2001 GMC Sierra Whining Noise
Transmission more than likely, It's letting you know there worn parts , Unfortunatly  there is no fix other than tear down and rebuild. If it's 4wd you may luck out and have a transfer case problem.  common TC problems are low or no oil and oil pump wear, there are many things in the trans that can whine , Planetary gears, pump etc etc
