02 Chevy Silverado 2500HD
Depending on what exactly you are replacing, you may wish to stick with 2500/3500 series w  the 2" body lift (IDK if yours has it, it probably does if it's an 2500HD).  The external panels are mostly the same, bumper and grille trim is different to account for the body lift, and I know radiator grille support is different, but other bits could be different as well.
And from swapping various body panels on my '04, it's easier if you stick to stuff from the same year or newer, as they seem to have made the panels backwards compatible (so if a hole was in spot X in an '01, it'll be there for following years, but newer stuff may have holes/welded nuts/extra braces that older parts didn't).  And there was a significant split around '02' or '03, where GM changed all the computers and wiring harnesses, so there may be other things you may encounter doing a full body swap to a newer body.
