99 chevy extreme 4.3 vortec
I put new plugs and wires on my truck, it ran so much better that day. Next morning I went to go out in it and it wouldnt start. new fuel pump relay, ignition control module replaced. still not starting. Any help would be appreciated guys.
Fire to the plugs or just at the coil? Check the ignition rotor for a burn hole . What is your fuel pressure? Do you have injector pulse? Any codes? If all that checks out possible timing chain issue, Does it start with a shot of carb cleaner?
Give it a shot of carb cleaner and see if it fires. you need to get a scan tool to get the codes that set limp mode although I don't think there was such a thing as limp mode in 99
Edited by richard wysong
