New cluster in, but new fuel gauge hinky
I wonder if the cluster came from a truck with a 34 gallon tank, as it now reads above full for a lot longer than the old one, and when the Low Fuel alarm comes on, it is almost too late to get to a gas station.
Does the 34 gallon tank have a different sender than the 26? Or do they just tell the DIC what tank is on the truck and it adjusts accordingly?
I suppose I could just add some resistance in series or parallel with the sending unit to adjust it. Anyone know the expected resistance for full, and empty?
26 gallon tank: remaining gal fuel level
E = 197-250 OHMS 0-3.1 gal 0-13%
1/4 = 150-190 OHMS 8.7 gal 30-35%
1/2 = 118-140 OHMS 13.5 gal 50-55%
3/4 = 83-110 OHMS 19.7 gal 72-78%
FULL = 40-66 OHMS 24.5 - 25.9 gal 88-100%
LOW LIGHT COMES ON AT 208-218 OHMS 4.3 gal 11-17%
34 GALLON TANK
E= 196-250 OHMS 1.2-4.1 gal 4-14%
1/4 = 155-195 OHMS 11.6 gal 30-36%
1/2 = 117-151 OHMS 18.6 50-58%
3/4 = 80-112 OHMS 25.7 gal 70-80%
FULL - 40-62 OHMS 32.6-33.4 88-99%
LOW LIGHT COME ON AT 218-229 OHMS 6 gal 11-14%
There is also a 31 and 37 gallon tank for the Suburban (if your cluster came from one of those)
Info from GM service manual
Well, after crunching those numbers, there isn't that much difference. Certainly not enough to reflect what I am seeing. There would be about a 1 gallon difference when the low fuel light comes on, assuming the DIC can be programmed to tell the fuel gauge what size tank it is reading.
Guess I can learn to live with it, as long as I have a trip odometer to back me up.
