Flasher Unit Location
hey guys, i have a question. my friend has a 06 silverado ss, and he just updated his turn signal bulbs to leds, what he wants to know is where are the flashers located, so that he can change them to flashers that work with led bulbs... any help appreciated.. thanks
bump, can anyone help me
Here is a diagram for him:
Document ID# 786377
2006 Chevrolet Chevy C Silverado - 2WD
Hazard and Turn Signal Flasher Replacement
Removal Procedure
  1. Remove the knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gages and Console.
  2. On the back side of the fuse block release the retainer while pulling the flasher (1) outwards.
  3. Remove the flasher (1) from the fuse block.
Installation Procedure
  2. Install the flasher (1) to the fuse block until the retainer clicks into place.
  3. Install the knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gages and Console.
Document ID# 786377
Document ID# 854980
Removal Procedure
  2. Remove the I/P cluster trim plate bezel. Refer to Bezel Replacement - Instrument Panel (I/P) Cluster .
  3. Remove the knee bolster screws.
  4. Unsnap the top of the knee bolster from the I/P assembly.
  1. Notice: Refer to
Fastener Notice in Cautions and Notices.
Snap the top of the knee bolster into the I/P assembly.
Install the knee bolster screws.
Tighten
Tighten the screws to 2 N·m (18 lb in).
Install the I/P cluster trim plate bezel. Refer to Bezel Replacement - Instrument Panel (I/P) Cluster .
Document ID# 854980
