Cool Zr2 Posted February 23, 2008 Posted February 23, 2008 Their instructions say that the 5th wheel hitch mounts may interfere with the mount location of the air bags, can anyone tell me if they are running both without a problem???? Thanks
Dently Posted August 21, 2009 Posted August 21, 2009 Guys, I don't know about interference with the 5 th wheel, will depend on the manufacture of the 5 th wheel, but I know You don't want Firestone ride-rite air bag system. I purchased and installed them over a year ago, just had my first failure.. Called the Tech support, they had me send photos of the installation, they agreeded I had installed them correctly, but they would not cover the blown air bag. Their lifetime warranty only coves defects in materials and workmanship not design flaws. I had the correct pressure, but when the bags fully compress it pushes on the heat shield and cuts the air bag. With their design, you remove the factory joust bumpers so now the air bag is the joust bumper, a lousy design. Goodyear air bags can be ordered with a hard rubber joust bumper internal and their bags are much stronger and rated higher... also save your self some money after installing this kit I could have fabricated a similar kit in about an hour, bought the Goodyear bags 2 for $119.00 on ebay and not had a failure. If you do buy the Firestone kit do not install the heat shield, fabricate your own not connected to the air bag.--- just my opinion
96chevy7.4L Posted August 21, 2009 Posted August 21, 2009 of you use the reese and the firestone air bags you will need longer bolts as they both use the same mounts in the frame. I ran into this issue with my 3/4 ton when I had it. better off with the helwig helper springs then the air bags just my opinion
cliobogger Posted August 21, 2009 Posted August 21, 2009 ha ha, dently tells his story on every air bag post there is.
