Stupid Mistake When Changing Oil
So I got ahead of myself when changing the oil in my truck today. I forgot to oil the gasket on my new oil filter before putting it on. Is this likely to cause any problems besides possible making it a little tough to get the filter off at the next oil change?? A little help to ease my mind please!
just make sure no oil leaks
if u used a quality filter they usually come with a coating of grease, stick with factory when it comes to oil filters.
I cranked it when I got done and backed it out to switch places with another vehicle in the driveway checked, and no oil was leaking. Haven't actually driven it yet so I guess I will just keep an eye on it. I used a Fram oil filter BTW.
Don't worry about it. There won't be any problems.
Don
+1
But here, take this so you don't forget next time... :lol:
no problems...just make sure you check next oil change that the gasket comes off the block and is not stuck
HAHA I deff wont forget next time.
I prefill the filter and then dip my finger into the oil to coat the gasket - that's my way of not forgetting.
I do the same.
The oil on the gskt just keeps it from sticking and grabbing when you are tightening it. Makes it spin around nice and easy with the filter and it may help when it comes time to take it off.
I am sure you do not want to hear this, but you should use the search function on this forum or any other for that matter and search Fram Filters. Not that they will every cause you any problems but they are the bottom of the food chain when it comes to quality. There are many good filters out there, Wix, (NAPA and CARQUEST's premium filters are supplied by Wix) AC, Amsoil, some say the Mobil filters are great. Do a little digging and you will see that not many folks who think much of their truck will use a Fram.
I was a professional oil change jockey for seven years, and I couldn’t have said that any better. :lol:
    250.3k
    cz2653
    cz2653
  • Who's Online   3 Members, 0 Anonymous, 1,309 Guests (See full list)
    • I did a search outside of this forum and came across a thread from this forum from two years ago which was amusing but one I recall now from a trusted member who had himself had to add a quart on his brand new truck to bring it up to near the level plug level. Then after accumulating 5000 or so miles on the truck he pulled the cover to drain it out and wiped out the bottom of the diff housing and put the factory cover back on and in his case it took exactly 4 quarts to bring it up to within that 4/10 of an inch below the fill/level check plug, far more than the GM spec. That is a big difference between that GM spec ( which is why the GM diffs are below the level they themselves say they should be when coming out of the factory ) vs what amounts to around 8 pints of oil.    My own truck when I first got it home from new, I had not measured how much volume mine took since I used a hand pump on a 6 gallon pail of gear oil to top it off but I had measured it by using a bent wire on the flat shop floor after the truck sat overnight and a ruler and it was exactly 1" below the bottom of the fill hole on the rear diff. That fell right into line with what others have measured from a factory filled rear diff on these HD trucks, however the GM instructions are to fill from within between 4/10" of an inch or up to the bottom of the fill/level check hole as the full range. So that is why it alarmed me when you mentioned not seeing any oil in that window although I wasn't sure if that diff cover held the exact same amount as the factory cover so can only speculate its probably very close to retain the same oil flow characteristics over the top that the ring gear provides with the factory curved cover vs some of these odd flat back diff covers ( the whole video Gale does on that about some of the goofy after market covers out there ).
    • I agree it's ambiguous, and somewhat complicated with a shared application. For S&Gs, I just looked on Amsoil's website for a 2023 Ram 2500 with 6.4 gas. https://www.amsoil.com/lookup/auto-and-light-truck/2023/ram/2500-pickup/6-4l-8-cyl-engine-code-j-esb-j/   There's a lot of listings for Ram rear differentials, and too early in the morning to dig into the variants. But there's a big difference in fluid volume called for between them and GM applications, assuming it's the same axle assembly.    So, if GM differentials tend to be underfilled, what does everyone think about a 7 pint fill, as opposed to the 6.3 pints listed on Amsoil's website? It would somewhat conservatively split the difference between Ram and GM specs.
    • Thanks for the reply’s everyone.  I will try to find the alignment printout and post that up.  Sounds like I’ll be taking it back to have the alignment re-checked
    • ok,good to hear,  being 10 plus years old i was thinking of changing them, but ill leave them be.   thanks for the help
    • Can I ask if you are having issues with the current coils?   With all of my years around LS engines, the stock coils are the best hands down. If they aren't giving you any problems, do no change them. They can go 200-300k miles easy without a hiccup.
