Add-a-leaf For 2008 1/2 Ton
Does anyone know of a leaf spring kit for a 2008 Crew Cab Silverado with the 69" Bed? I have a shell and usually carry around a bit of a load. I'm definitely not at the load limit, though. I don't like the droopy look or the constant flashing of on-coming head lights.
There seem to be kits available, but they all stop at model year 2006. Does anyone have any experience with this?
Thanks
OK - looks like most like air bags. I had a bad experience with these last time I had a 1500. They jumped out of position during hard 4-wheeling. Any tips on which air bags are good?
Thanks for the tips.
I have pro comp add a leafs...The springs for a 99-06 1500 will work on the 07+.
Like Ranger said, kits for the 99-06s will work. He put a pro comp kit on his GMT900 and I installed a trailmaster AAL kit on my ext. cab 4x4. I got a solid 3" of lift in the back and it takes ALOT more weight to level out the truck, now!!
...As far as air bags, show me a good set for the $70 I invested in these springs and I'll agree they're the only way to go! :D
Do you have a spring shop around where you live?
We have one here,I had them add a leaf to a couple of my past trucks,$100 bucks installed!!
It seems that 1500 series 4X4 trucks have somewhat weak rear leaf springs. I was amazed that there are only three (?) leaves on each rear spring. I would not mind adding beefier springs to mine too. So far I have not had issues towing my boat or utility trailer, but loading about 1,500 lbs in the bed would make the truck sag for sure.
Maybe I should install deuce and half ten leaf springs? :D
I have a set of Super Springs on my truck, they are the 3K lbs variety. I like them because they don't effect the rear suspension until you load the bed of the truck, so empty you maintain the stock ride comfort of the truck. I have had a full load of mulch and rock and not had the rear axle hit the bump stops!
