Showing results for tags 'rough idle'.
Recently I had my lifters collapse and i brought it to a shop and they put a new motor in it with the AFM/Dod delete. Ever since I’ve had a check engine light for P219A P219B PO300 that I can’t figure out. It drives fine but at idle it has a rough shake. The truck has new coils,wires,plugs. New injectors New 02 sensors New high pressure fuel pump. New exhaust manifold gaskets. I cleaned the maf sensor and throttle body. I sprayed brake clean around the intake gaskets and there was no change in idle. I did a compression test and cylinders 1,4,6,7 have 180 psi and 2,3,5,8 have 210 is this normal? Any information helps.
2019 Silverado facelift 5.3 103000 kms getting the generic Misfire code when I scan it it shows service esc, service parking break and a flashing CEL. It has a rough idle and clunks hard when coming to a stop almost like being rear ended. This isn’t what’s weird it also occasionally billows white smoke out of the tailpipe for around 10 seconds this only happens about once every 2000 Kms. It also backfires occasionally and sometimes is a little extra Smoky the smoke isn’t blue it’s a thick white but doesn’t smell like coolant it smells like gas the coolant and oil levels also never change the normal exhaust also smells very rich spark plugs look fine I changed them and the coils dealership says they don’t know what’s wrong with it can anyone provide me some insight?
I have a 1994 Chevy C1500, 5.7L engine. My truck idled high and I finally got around to replacing the idle air control valve. This didn't fix the problem and it continued to idle high. I determined the issue to be a vacuum leak, so I replaced my vacuum hoses and checked connections. I tested by spraying carb cleaner and the engine still bogged down at this so I cleaned the throttle body and made a new gasket for the throttle body because that one was falling apart. After doing this, the truck began idling extremely low. It threw the EGR code, so I have since replaced the EGR valve and EGR solenoid. Neither of these fixed the problem. Next on the list is to replace the throttle body gasket along with the distributor cap and rotor. Additionally, my truck will also struggle to accelerate. The confusing part is this- there seems to be no rhyme or reason as to the low idle. Sometimes, the truck idles in park at 800-900 RPM and is able to adjust the idle to the load of the AC being turned on. Other times, it idles in park at what is most likely 300-400 RPM because it doesn't even register on the gauge. It does not seem to have any consistency as to if the engine is hot or cold- it just seems to be whenever it feels like it. This evening, while working on it, it started straight up once and idled great at 800 or so RPM and handled AC and headlight load. While the AC was running, we unplugged the wire that makes the AC compressor run- this dropped the RPM down to around 700 and it never recovered from that. The truck was turned off and started again. This time it idled around 700. Truck was turned off and started again- this time it idled around 500-600. The truck was turned off and now it had to be given gas to start and idled low, around 400-500. Any ideas to explain what is causing this? We are all going mad trying to troubleshoot this and figure it out. We've checked so many things and nothing seems to be causing the problem. Any help would be greatly appreciated.
- low idle
- rough idle
