If you have a 2018 or 2019 Chevy or GMC truck sitting in your driveway, you need to head over to the NHTSA site and check your VIN immediately.
General Motors has issued a targeted safety recall affecting 2,785 trucks due to a manufacturing defect that can cause the roof rail curtain airbags to literally rupture or launch components directly into the cab.
What makes this recall particularly wild is how GM caught the issue. According to official safety reports, a dealership reported a 2019 Chevrolet Silverado that was simply parked and completely unattended when its passenger-side roof rail airbag suddenly exploded out of nowhere. The rupture was violent enough to blast the end cap off the inflator, tearing up the truck’s headliner and visibly damaging the steel roof line.
Here is the breakdown of the affected trucks, what caused this ticking time bomb, and what you need to do next.
The Affected Trucks
This recall specifically targets a very precise lot of trucks built during October 2018. Because GM uses part traceability data to pinpoint the exact supplier window, not every single truck built in these model years is included, which is why checking your specific VIN is critical.
| Make & Model | Model Year | Production Window Affected |
| Chevrolet Silverado 1500 | 2018 | Oct 03, 2018 – Oct 24, 2018 |
| GMC Sierra 1500 | 2018 | Oct 03, 2018 – Oct 24, 2018 |
| Chevrolet Silverado 2500 / 3500 | 2019 | Oct 08, 2018 – Oct 27, 2018 |
| GMC Sierra 2500 / 3500 | 2019 | Oct 08, 2018 – Oct 23, 2018 |
The Cause: A Microscopic Crack and Trapped Moisture
The root cause of the rupture reads like a masterclass in how a tiny manufacturing error can come back to haunt a vehicle 7 to 8 years down the road.
The components were built by supplier Joyson Safety Systems in Mexico. GM’s investigation revealed that two separate supplier defects occurred at the exact same time:
- The Mechanical Flaw: A microscopic crack was introduced into the inflator’s pressurized steel canister during the manufacturing process.
- The Environmental Catalyst: A small amount of water was inadvertently left inside that same canister after it went through the factory washing process.
By sealing moisture inside a pressurized container with a microscopic structural crack, the supplier inadvertently created the perfect recipe for stress corrosion cracking. Over the last nearly a decade, that trapped moisture has been silently eating away at the integrity of the steel canister until the internal pressure finally caused it to split open. If this happens while you’re driving, the compressed gas can launch metal shards or the inflator’s end cap straight into the cab, creating a massive risk of injury.
The Fix (And a Bizarre Rule for Technicians)
To fix the issue, GM dealers will replace both the left- and right-side roof rail airbag modules completely free of charge for affected owners.
Interestingly, the official service bulletin contains a highly specific safety rule for the mechanics working on these trucks. Because these unstable pressurized canisters can react poorly to extreme heat, GM warns that the interior temperature of the truck must be 90°F (32°C) or less before the technician can even begin the repair or deploy the old airbags. If a truck has been baking out in the sun, the dealer is instructed to pull it into an air-conditioned bay or run the truck’s max AC for at least 20 minutes to cool the headliner down before touching the modules.
What You Need To Do Next
VINs officially became searchable for this specific campaign on May 21, 2026. Since the remedy parts are limited initially, GM is telling dealers not to order these for shelf stock, saving them strictly for affected vehicles that come through the door.
Official owner notification letters are scheduled to hit mailboxes starting July 6, 2026. However, you don’t need to wait for the mail. You can check your VIN on NHTSA.gov right now using recall number 26V325 or on the official General Motors Recall by VIN Checker
If your truck is flagged, reach out to your local dealer to get an appointment scheduled, or contact customer service directly to track part availability:
- Chevrolet Customer Service: 1-800-222-1020
- GMC Customer Service: 1-888-988-7267
- GM Internal Recall Number: N262557310
Join the Discussion in Our Forums
Is your truck on the list, or are you heading to the NHTSA site right now to check your VIN? Let us know if you’ve already dealt with an open recall or if your truck is affected by this campaign. Drop a comment and join the conversation with fellow owners in our community forums:
- Chat with half-ton owners in the Silverado 1500 & Sierra 1500 Forum
- Discuss with heavy-duty owners in the Silverado HD & Sierra HD Forum
- Browse all platform discussions on the main GM-Trucks.com Forums
