If you drive a newer GM half-ton with the 3.0L LZ0 Duramax turbo-diesel, you might have noticed an annoying buzz, rattle, or vibration coming from the passenger side of the cabin. It typically happens when the truck is under a light load, making it incredibly frustrating to track down during daily driving.
Before you start tearing apart your interior door panels or dashboard looking for a loose piece of plastic, you need to look under the hood. The issue isn’t inside the cabin; it’s bolted to your exhaust.
General Motors has released Service Bulletin PIT6300B to address this exact complaint, and the fix is a simple hardware inspection.
Have you had this or a similar issue? We want to hear from you! Comment in our Community thread for this issue.
The Affected Trucks
This specific rattle is isolated to the newest generation of the 3.0L inline-six diesel (engine code LZ0). According to the bulletin, it affects:
The Cause: Cracked Brackets and Broken Studs
The noise you are hearing is actually the catalytic converter vibrating against the engine block or exhaust assembly.
GM has identified that the catalytic converter brace/bracket—located on the passenger side of the engine bay—is prone to failure. Specifically, technicians are finding two main culprits:
- A Cracked Bracket: The metal brace itself (Item 1 in the diagram) can develop a crack, causing a metal-on-metal buzz under light acceleration.
- Missing or Broken Studs: The hold-down studs (Items 2 and 4) or nuts (Item 3) that secure the assembly can break or go missing entirely, allowing for significant vibration.
The Fix
The correction is straightforward: a technician needs to inspect that specific brace for any signs of cracking or missing hardware.
If you take your truck to the dealer, reference Bulletin No. PIT6300B. They will inspect the bracket and repair it as needed—either by replacing the cracked brace or installing new studs and nuts to secure the assembly.
If your truck is still under the factory bumper-to-bumper or powertrain warranty, this repair should be covered under the actual cause and repair needed.
