Showing results for tags 'keyless alarm'.
I left my truck key in the ON position for about 60 minutes. After some time, I started hearing a ping every 30 seconds or so from the interior beeper (the same beeper that would ping if the headlights were left on) When I tried to start the truck, I got the typical click, click, click of a dead battery. However, I was able to jump-start it. I put it on the charger after driving for about 20 minutes, and it showed nearly full. After the jump-start, the Battery, ABS and Seat belt lights are constantly lit. The fuel level, oil pressure, water temp and battery gauges do not work. I see them dip down to the resting position and then they set themselves to the low-point on the indicators after the engine starts. The power windows do not work. The driver preferences (seat adjustment, side mirror settings) are not working. I get no sound from my speakers. The remote lock/unlock is not working. A/C is not working - the fan speed and temp control works, but A/C compressor is not running. Hopefully, this is a known issue and has a simple solution....
- 4 replies
- gauges power windows
- keyless alarm
