Showing results for tags 'valve cover gasket'.
Hi everyone, first time posting, but long time reader. I usually try to avoid posting when I can, and just browse the threads and read about related problems and figure it out from there. Even though I've found many threads that are similar to the problem Im having, I still can't narrow it down to my next step. so if anyone can help, it would be greatly appreciated. Ok so, BAD oil leak problem with my friends 2005 GMC Sierra 1500. It's had this leak for a while, but it's gotten to the point now where it's starting to leave puddles. I power washed the entire area, and I actually got it pretty clean. Today when I looked again to see if I could trace the source, I had a much clearer picture of where the leaks are actually coming from. From what I've read it seems as though it could be the valve cover gasket, the crankshaft sensor, the rear main seal, or even the oil pan gasket. My problem is that to me, it looks like it's coming from almost all these places. I looked inside the bell housing and I don't see it looking completely soaked in oil. It does however, look like the leak is mainly coming from in front of the bell housing behind the engine, in between the two. I'll attach some pictures. These would be from overnight after I power washed it, so the oil hasn't blown anywhere from being driven or anything. Thanks so much to anyone who's got any ideas!
- 14 replies
- oil leak
- bell housing
