All Activity
This stream auto-updates
  1. Past hour
  2. Yes that's right, it's the upgrade that includes the overload spring and all that stuff. Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings. Exactly you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
  3. Today
  4. You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against. The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide. As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
  5. This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
  6. My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe. I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires! And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
  7. Common Sense Assembly Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit. What? Not everything needs to be a five thousand word essay.
  8. We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
  9. Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
  10. I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off. The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures. I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
  11. That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention. I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
  12. That's good to know, but I don't think I'll even be running them under 45 in the rear unless it's on the sand or something but will only be for a short distance anyways! I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
  13. That's bad. Like, its probably destroying the stub axle the CV slides into. Do you have a proper lift installed with differential lowering brackets? Did you install AT4/Trail Boss factory CV axles?
  14. Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
  15. Gas on the hi-way followed Mobil's lead and went up a dime to $3.79, Sunoco was still $3.69 though. The truck stop went up twice today, first a dime then a nickel. Diesel $5.35 at Sunoco but $5.79 next door at Gulf
  16. Yesterday
  17. There are no available updates in my settings, but the dealer can still flash the latest. They told me it was risky to force flash updates because if anything went wrong with the update that I'd be on the hook for the repair costs. They recommended just leaving it as is.
  18. I put a set of the Eibach Pro Truck 2.0's on mine this past weekend. Lower bolts def was the trickiest part. Def leave the top bolts very loose, as in the nuts barely started. Have a jack under the LCA so you can move it up and down. One of mine I had to barely unclip one side of the spring nuts as to create the odd angle. With those spring nuts being fairly loose, and holes slotted, it can be done. Just have to keep at it. One note, I used a LONG extension with deep barrel socket on the inside nut on the passenger side, was able to reach it from the top. Swivel head ratcheting wrench on all the others. Couple of observations: sure seems like the rear lifted some, which I know sounds crazy since I kept the original leafs. I ran the front shock adjustments all the way up to the 137mm measurement. Unfortunately I didn't measure rear wheel arch height before. Front measure about 5/8" higher than before, but I'm sure it had settled some. Had 110,000 miles on the original Ranchos, I can't express how much better the ride is now.
  19. If it's not put to normal and right, it won't be from lack of trying on your part. Or because you didn't spend the money that needed to be spent. You're committed and thorough for sure.
  20. Just out of curiosity, why would there be no available updates if in fact updates had previously been available but not installed? Does a vehicle have to be under warranty to receive such updates?
  21. Thanks. The wheel hub looks fine and no play when moving the tire. I tried to take the axel out but couldn't get it to budge off the front dif. It's to hot for this stuff, I need air conditioner in the garage. Lol
  22. If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
  23. Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability. For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
  24. Sure. Buy it for me
  25. Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer.
  26. I ordered the Snap On...waiting for it to come in later this week or early next week. New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts. Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down. Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart. So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend. My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone. I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
  27. Yes. You need to check out that thing, and the hub further.
  28. Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks https://youtu.be/ZnW7PPRmjJY?feature=shared
  1. Load more activity
