Showing results for tags 'water pump'.
Installed a new all aluminum Cold Case radiator in my 06 Sierra 1500 4.8L and I’m having trouble getting up to operating temperature in the normal time frame. I would think this will especially be an issue in the winter, but I’m in Texas so winters are no exactly terrible. Is this something I should be concerned about in the long run not reaching op temp on the majority of my drives? Getting my temp to the 200 degree standard operating temp will take me about 40min of non stop highway driving while the fans are running with the AC on. My temp will climb to the 185-187 thermostat opening fairly quickly 10-15min but as it opens and the fans run, it is just too much cooling for it to ever reach op temp in a decent time. Also if I keep my fans off, and it does reach 200 degrees, in 15-25min, once I turn the fans back on, the temp will drop to 185-187 within 5-10min. I know this radiator was a bit overkill for my stock application, but I wanted an aluminum rad to not worry about leaking issues in the future from plastic rads.
oil cooler Duramax Oil Cooler Pipe HELP!!!
BuffaloPunch posted a topic in Duramax Diesel & 8.1L Big Block
Hello Anyone. i have a LBZ Duramax, and i have just put in a new water pump and rebuild the oil cooler and the pipe that connects them i put in after and i pitched a gasket and it eakd then i took it out again and put two non OEM gaskets on there and it seemed to stop leaking when i added coolant but when i fired it all up it pissed out again so my question.. what is the propper way to put the pipe in, i could no imagin putting it in the cooler then putting it back on the truck, do you put it on the water pump first maybe then put it in??? or can you some how use gasket maker instead??? i need help-
- duramax
- water pump
