*****THIS MOD ONLY WORKS FOR BULLY CR-007A, OR THE LIKE. THE TAIL/BRAKE LIGHT HAS TO BE A 4-WIRE WITH SMART-BOX.*****
*****Sort the images by "Caption" to put them in order.*****
1. Get a NEW Bully Truck Hitch Tail/Brake Light (HAS TO BE A CR-007A), a BLUE wire splicer/crimp, and RED LED 1157 Bulb (one for each assembly).
My new Bully Hitch Cover Tail & Brake Light, unaltered. Unpack the light, and gently stretch out the harness.
a. Get the Zip-Ties out of the way from the black box and the harness
You can work the two zip-ties loose and out of the way. Take the smaller one toward the plug, but DO NOT PINCH THE YELLOW WIRE LOOP!!! Take the larger one off of the circuit block and toward the light assembly. If you want, you can cut the zip-ties away, and replace them with new ones, when you’re done.
b. Pull wire harness up through the block, with a couple inches of harness exposed
Take the black sheath and slide it as close to the plug as you can, exposing the wires inside of the assembly. This one was all the way in against the lamp housing. I pinched a little bit of the sheath and push the wires through towards the assembly, until I could pull them through from inside the assembly.
c. Cut the BROWN wire in two places,
i. Even with the opening of the mount (NOT DOWN INSIDE), and/or
Cut the BROWN wire about even with the end of the block. If you can cut it too short (down inside the block) or a little long, you will have chaffing issues later because you will not be able to pull the harness back in out of the way.
Just a closer view of the BROWN wire cut. NOTICE that the cut is about even with the opening.
ii. At the plug
IF YOU WANT, cut the other end of the BROWN wire at the plug, or leave it alone, you already cut the source for the light assembly to shine with the tail lights. I removed mine with each one that I have done. Pull it out, and you can either throw it away or keep it for another project. I'm debating on using it re-modify my original light, so it works just like this one.
d. Connect blue splice:
i. Slide YELLOW wire into the pass-through (open side) of the splice
ii. Slide BROWN wire into the splice (“hinge side”) until it stops
iii. Pull YELLOW wire thru splice until it’s even with BROWN (same length from splice to bulb)
iv. Crimp the splice
v. Fold the lock over & lock it
Slide the YELLOW wire through the opening in the splice, MAKING SURE THAT THE CLOSED OFF END IS AWAY FROM THE LAMP, toward you. Insert the BROWN wire into the other opening, and slide the splice down along the YELLOW wire until the BROWN wire is completely inside the splice, both YELLOW and BROWN are even between the splice and the bulb housing. Take a pair of pliers, smash the splice blade down into the splice, and fold over the lock.
e. Pull wire harness back into the block
In the same manner that you slid the sheath away from the light housing, run the sheath back down to the splice. Pull the harness back down into the assembly until the sheath almost disappears through the inside hole. DO NOT pull the harness too tightly down into the assembly.
f. Install RED LED 1157 Bulb (OPTIONAL)
I chose to replace the conventional 1157 bulb with an 1157 RED LED Bulb, make the light shine more RED.
g. Re-zip-tie harness and little black box
Take the zip-ties and put them back where they were when you started. I slid the small one down near the sheath, put the larger one back on the circuit box, and tightened both of them up a little, since I removed the BROWN wire. I then trimmed off the extra zip-tie that I had pushed through, to clean it up.
With this mod, the light functions/illuminates as follows:
1) Locking/Unlocking the vehicle
2) Remote Starting - will only flash when the lock button is pressed during the sequence
3) Applying the brakes, and
4) EMERGENCY FLASHERS
The circuit box keeps it from flashing with the turn signals, but allow it to flash with the emergency flashers.
You may need to purchase a 12” 4-wire extension for it to receive power, about $4 @ Walmart. On my ’06 & ’10 Ridgelines, the harness was long enough to reach. BUT on my ’15 & ’18 Silverados, I had to buy an extension.
2. Performed operational check. Light illuminates as follows:
I will shoot a video of the operational check out of this modified light sometime in the near future, with some family assistance.
a. Lock/Unlock visual indication,
b. Remote Start visual indication (with BROWN wire removed, it will only flash with tails, like Lock/Unlock),
c. Press brake pedal, and
d. Emergency Flashers.
- Album created by Ravenkeeper
- Updated
- 12 images
- 510 views
Recently Browsing 0 members
