All Activity
This stream auto-updates
  1. Past hour
  2. Just changed mine at 35,115 miles. I carefully removed the gasket to get it out of the way. Then turned and twisted the pan just right and it slid right out. It can be done. It also went right back in. My pan very close to no clutch material in it. The magnets also had very little on them. The truck us used but not abused. Tow a 28.5 foot camper 5 or 6 times a year just under 6k loaded and a 3000 pound bass boat. Live in ohio not terribly hilly. Pretty happy how it went today.
  3. Today
  4. $4.19 or so for 87. $5.40-5.80 for diesel.
  5. From my above post, I got the whole assembly out. Had to use YouTube as there was one hidden bolt. What happened was GM wraps the little wires around a couple pins to hold the wires in place. The pins made the wire so tight that the bulb would only turn about 80 degrees. That last 10 was stopping the bulb from being able to be removed. Once I removed the wire from the pins the bulb came out no problem. Knowing that now I wouldn't need to pull the whole assembly as the wire can be pulled from the pins with the assembly in place. Thanks Jim
  6. Mobil and Gulf now $3.89, truck stop $3.86, Sunoco still $3.69. Up Up and away!
  7. Yesterday
  8. So, these updates are strictly for the radio? They don't update any of the truck's modules?
  9. Dexos is for engine oil. Not gear oils.
  10. That's about 4-5 build versions old if you have the 8 inch IOS or IOT radio. V155 is the number that tells you what version of software it has. Newest IOS/IOT radio software is V171 which was released June 2024. You'd have to pay out of pocket for the update at the dealer. TSB on the current software is 24-NA-108. MC-11004657-0001.pdf
  11. You'd be the first to make it happen if you tried it that I know of. You'd have to order a pair of option code DLF mirrors for a Chevy HD truck, and then attempt to swap all the components from those LTZ 1500 mirrors you bought on to the DLF HD mirror mount. If it would work.
  12. It's not on the dexos list. No need to pay GM just to be on the list. It is a great product and will serve you well.
  13. Is the AMS Oil Dexos certified? Just wondering as I would like to change both front and rear differential fluids shortly......
  14. Decided to check for updates for my 2021 Silverado 1500, and the system showed no updates available. When I checked the build number, it looks like it hasn't been updated since it was new. Does this look like I'm missing a ton of updates? Thanks
  15. I can see them dropping the SLE trim line but the SLT trim?? I think that's a bad move, I know several acquaintances that always buy SLT trim, usually every 3-4 yrs. They would never consider an AT4 (older) and the Elevation is a cheap model in their eyes.
  16. I assume I'd be opening up pandora's box if I tried to source the early WT mirrors and tried to get the 2500 bases fitted to the rest of the 1500 mirrors...
  17. Get a Range AFM disabler or have someone with a tuner go in and turn off AFM. Simple fix. You should be lucky it didn't lunch the camshaft.
  18. 1500 mirrors will NOT fit HD. They do NOT share doors which means they don't share mirrors. There is only one small mirror for HD and it has nothing but heat and power glass. If you have cameras and blind spot, your only option is the factory equipped towing mirrors.
  19. $5.06 at our Kroger today
  20. I still kick myself for not buying your last truck when you had it for sale. I had two at the time so I passed, damit.
  21. I did some driving around the woodlands area and saw some 3.31 a gallon prices. Usually my local Kroger’s is the cheapest. It hasn’t always been here lately. I usually get the benefit of my Kroger card. I don’t add that in for this purpose.
  22. So resurrecting this thread... Is it possible to get the 1500 mirrors with power folding, blind spot and 360 view that have the "square" mounting stud pattern? Did not realize there was a difference and ordered '25 1500 High Country mirrors to mount on my '25 2500HD LT and came to the unfortunate discovery that the mounting studs have different patterns.
  23. Seeing the same thing here, the truck stop is usually a couple cents cheaper than everywhere else but they were higher than surrounding stations this am, will see if the others go up this afternoon $3.76 truck stop, $3.74 Gulf, Sunoco still $3.69 but the tanker was there this am so that may change, Mobil $3.84
  24. Gasbuddy lists Costco in Mansfield as the cheapest in Texas at 2.93 for regular but also more than one place around that 3.00 level in Houston. I am guessing that is probably some of the lowest fuel prices in the states ?
  25. Resurrecting this thread. I was wondering if anyone has information about the differences between mounting bolt patterns for mirrors and how to understand what mirrors have what pattern.... I have a 2025 2500HD LT and want to swap my stock power folding, blind spot and 360 view mirrors with 1500 mirrors with the same features. I ordered a 2025 1500 High Country mirror but came to find that they have different mounting patterns as seen in this picture. @modernmetal did you have issues with the mounting pattern?
  26. 3.51 Kroger’s in Montgomery Tx. Surprisingly they’re not the cheapest. That is unusual.
  1. Load more activity
