All Activity
- Today
Audio Dampening and quiet
Afennell19 replied to DJ Annoyed's topic in 2019-2026 Silverado 1500 & Sierra 1500
Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time. I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens? -
2026 Sierra 1500 Denali - Sound upgrade?
Afennell19 replied to d.lowrey's topic in 2019-2026 Silverado 1500 & Sierra 1500
I have a 2026 Silverado LT, the non bose as well. Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well. And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden. I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash.... Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while. Come to find out. The stock speakers are just THAT SH*TTY I cannot wait to have some decent sound in the truck What did you end up doing? -
Afennell19 joined the community
Parking Brake - Automatic Engagement Questions
newdude replied to SoCal Angler's topic in Troubleshooting, Warranty & Recalls
Its all automatic based on yaw sensor data. If enough incline is detected, it engages. My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal. The HD trucks use the same setup as prior years, the drum in hat park brake. But now with an electric actuator. If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out. Electric console shift will set the park brake on flat ground too. Pretty sure they've got it programmed to activate every time. -
Anyone install a a supercharger on your 6.6L L8T? Talk to me...
Some Assembly is Required
Grumpy Bear replied to Grumpy Bear's topic in Maintenance, Oils/Fluids, Detailing & Rust Prevention
Yes - Yesterday
Policeoff01 started following Feeling Vibration and Jiggles in 2024 HD Gasser Steering Wheel
Curious, did anyone ever get a fix for the vibration reported here. I have a 2024 Silverado with 6.6 duramax. I’m noting the same vibration resonating up through the steering shaft into the steering wheel. Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel. thanks.
Policeoff01 joined the community
richard wysong started following Pulsating Noise 4Cyl Mode
Hi friends - first time poster. I have a 2015 sierra Denali with 150k miles, I’m the second owner and she’s given me 75k of great service. I run a pulse AFM disable device. Starting Thursday when I exited the freeway after a short local ride it started idling rough, with an obvious misfire shake and was down on low end power. I got it home and hooked it up to my scannner and found no codes but in live data a pretty bad misfire on cylinder 5. I replaced the coil, plug and wire with all new OE replacements (Delphi gn10165 coil, acdelco wire and 41-168 plug). It’s still behaving the same way after firing the parts cannon at it. I know cyl 5 is a non AFM cylinder so I am not thinking this is AFM related but I’m kinda at a loss. injector? Bent pushrod? It’s running too well over 1k rpm to suggest those IMO. Has anyone chase this issue before and what was it? Any suggestions?
Gkistler joined the community
2017 Silverado L83 5.3l 6speed transmission Hello, not a new member but havent posted in a while and my old signup info isnt working so had to create a new account. anyways, I have an issue with my truck and hope someone can spread some light on whats happening: -when it goes to 4cyl mode it makes a clunk sound (but not when coasting or going downhill) -when in 4 cyl mode and under load it makes a load pulsating sound (not a tick). -goes away completely when in M5 gear or when plugging in an AFM delete. Im guessing it is one of 2 things but im not convinced of either to be honest. 1. lifter stuck in v8 mode 2. torque converter shudder realistically it doesn't seem like the TC as there is no physical vibration , and it never happens in v8 mode. but maybe? and wouldnt a lifter make a sound whether with load or not? any ideas let me know please. thank you!
zibzer2 joined the community
Chuck FB replied to Grumpy Bear's topic in Maintenance, Oils/Fluids, Detailing & Rust Prevention
Which has made me wonder with the various engine failures of a few brands in the last few years, is it sub par materials such as lifters etc causing failures, or bearing clearances on the crank etc or perhaps bad designing of an engine physically or causing too much load on the components due to the hp/torque they can push out of them. Or is the oil viscosity and additive package of current oils or a lack of oil flow by an oil pump not able to supply sufficient oil at idle or under high load at low rpm. Or is it every item I listed that combined together has pushed the limits so far to the left that there is hardly a margin of safety left and add in some fuel dilution and too long of an OCI and premature engine failure is the result ?. -
He is not saying that an SAE *W20 will have more viscosity than a *W40 due to MORE VII polymers. He is saying that although multiple *W40 may post in the PDS the same or similar 100 C and 150 C viscosities that the blenders choice of modifier TYPE and AMOUNT to get his chosen base to grade will not give identical real world viscosities in shear and at temperature. All will pass the SII test but not all will pass the 100 C HTHS (unpublished value) testing the blender does and relies on to get the required by law "percentage improvement' referenced to his last great work. Tis the problem with the lie. Once told others are required to support it. -
I have a `25, 1500 that auto sets on incline. Never knew that at first. I have the electronic shifter. Just think if it didn`t do that? Unlike a mechanical shift that you can muscle out of park, how would you get this thing out? That would be a problem. What I found out later is, I don`t have to push the button to release. Just put it in gear. Setting parameters? Don`t know if it`s possible.
2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options: SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving. When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off. The parking brake appears to be setting itself automatically. I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation. When is the parking brake automatically engaged? Under what specific circumstances? Can the auto set parameters be changed? I like the auto set feature. It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4). Thanks!
Can it still be Assembled II? Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh. But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded. That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie. Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it....... MOVING THE GOAL POSTS! OMG Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils) Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee. You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them. At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict. -
when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful. Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
Chuck FB started following Dave's Auto (custom engine builder) tear down of L8T and Software Update
I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
Chuck FB replied to mrjulian416's topic in 6.6L Gas V8 (L8T)
The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer. -
I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill San Jose
- Last week
davester started following Bench seat swap for 2021-2024 suburban
davester replied to Ahmed101's topic in 2021-2026 Tahoe, Suburban, Yukon & Escalade
probably won't get a response from that user, as they haven't returned to the site since making that one post. users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread... -
Sothpaw27 joined the community
Mchristie1992 joined the community
Wow I'm in a pickle. (Broke down truck) and a story.
Atlas replied to Atlas's topic in The Off-Topic Bar
Thanks - I wasn't quite caffeinated this morning. 2:1 makes sense, turning the crankshaft 360 degrees will turn the cam 180 degrees, and had I done that, the cam's dot would be at 6 and the crank's at 12 again. I went ahead and took the sprocket off anyway, aligned everything dot-to-dot including the balance shaft just for s&g. I'm glad I did because I discovered no Loctite on the timing sprocket bolts. Maybe it's not required, but at only 20 ft-lb torque spec, those bolts aren't in there very tight. Cleaned and reassembled with some thread locker and torqued. A general observation: Less is more with RTV. If a little doesn't stop a leak, a LOT probably won't, either. RTV is thinly veiled revenge, in a tube...
