All Activity
- Past hour
SERCICE ESC message?
No F-bdy Bs replied to No F-bdy Bs's topic in Troubleshooting, Warranty & Recalls
Apparently, its a Brake Module of some sort, which is backordered with no ETA. Thanks, GM. -
Wow.....oil filters??? LOL!!
Facts tell the story, news agencies sometimes add spin. Some agencies more than others, and some have been found guilty of actually lying and making things up. If you think one or two agencies are the only ones who tell you the truth, more than likely you've only found your preferred flavor of spin, not a cornered market on factual information. And that's just as dangerous. Folks are going to lie to themselves anyway and form opinions which aren't based in reality or fact and they live amongst us.
Year/make/model/engine?????????????? From the looks of the piece you need, pushes into the airbox and then the big loop clips around the radiator hose? If you have a u-pull-it yard you could get just that piece and not the whole tube.
- Today
They will only sell the complete system. They don't let you pick things apart. $5 part or sell the whole thing for $150? Which do you think they want?
doylej24 joined the community
I have an unused GM Authorization code.
Atlas replied to s10dragracer888's topic in Modifications, Wheels & Tires
Unauthorized use will turn your truck into a 1995 Chevy Cavalier. Use with caution? Can you get a refund? -
newdude replied to s10dragracer888's topic in Modifications, Wheels & Tires
Garbageee -
OTA updates and radio still cuts out
StingerZ16 replied to wxman13's topic in Troubleshooting, Warranty & Recalls
Thanks for sharing. This is a nice nugget to have. -
s10dragracer888 started following I have an unused GM Authorization code.
As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1 https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
Matt Parker started following Clunk when putting truck into drive and reverse.
Matt Parker joined the community
richard wysong started following Needing this part.
Looks like it's riveted to me. What is wrong with that 1? Welcome to the Forum!
Some Assembly is Required
Grumpy Bear replied to Grumpy Bear's topic in Maintenance, Oils/Fluids, Detailing & Rust Prevention
Missing pieces of the Assembly Detergency vs Solvency Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution. Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change. How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job. So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on.... Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money. Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them. So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits). For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #). Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was. That kids is just the cleaning side. The side few pay attention to. -
davester started following Needing this part.
hit a junkyard.
Mann+Hummel since 1941 per their web site
B07 started following Needing this part.
Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
B07 joined the community
rav3 started following 2017 Silverado Front Bumper Valence/license plate holder
rav3 replied to Spencer_Waz92's topic in Modifications & Accessories
https://ebay.io/m/cTI46i -
m3n00b started following 2017 Silverado Front Bumper Valence/license plate holder
Some people can’t help it sometimes. We try not to judge too hard.
sherry299 joined the community
Spencer_Waz92 started following 2017 Silverado Front Bumper Valence/license plate holder
He mention Honda filters. I asked if I should be worried. And an explanation. I don’t think he needs any help. And now you made it about you, right?
Spencer_Waz92 joined the community
Cam Iarrobino joined the community
Mobil on the hi-way went up a dime this afternoon, now $3.79, surrounding stations no change yet still $3.60s, Lowest price local still $3.87 and up
