All Activity
This stream auto-updates
  1. Today
  2. Not so worried about folding or memory, but if that is the case I feel very dumb for not noticing that they connect to each other, so what you’re saying is the light in the back of the mirror will only light up when I unlock it? Or will it work with blinker too
  3. Aftermarket mirror doesn’t support power fold or memory functions. So key fob fold won’t work either. The two smaller connectors looks like they were disconnected. If you plug those two together, the blinker on the glass should work. Amber light on the tow mirror will likely come on as a your old puddle lamp (so when you unlock at night - it’ll turn on).
  4. what are the tow mirrors off?
  5. First time poster here, recently bought some tow mirrors off of my buddy and installed them on my 2014 Silverado 1500 ltz, my stock mirrors have the light in the lenses for your blinker with heat, power adjust, memory, and power fold. I noticed the mirrors I got have 3 total connectors but my stock mirrors only have 1. I plug the new mirrors in and the only function I have is the power adjust. No lights no fold nothing. I’m guessing I need to wire something or repin the connector, any info out there on how to do so? The pictures attached include a picture of my oem connector with only 1 connector, and the aftermarket ones with 3 connectors. I apologize if I post this in the wrong section
  6. Yeah, cartridge filter on this one. I actually ran R&P when I first bought it and didn’t see anything in it. But it was a fairly short run so we’ll see. Of course!
  7. Not sure if this got posted yet but TFL got hp numbers. 5.7 is 400 hp 6.6 is 475 hp
  8. Do not assume any updates apply to your vehicle. Maybe the best thing to do is, leave well enough alone. I was at the Cadillac dealer once for a system software update fix (not a recall) for a known issue with fuel gauge inaccuracy in some CTS+4. Supposed to take 30 min. but as I was talking to a person in the showroom I spotted them pushing my car outside. Just about then the SM came over and said, while we were running the update the cpu froze up and we have to get a new CPU. I'm getting you a loaner, we hope to have a new one over night and I 'll have them bring the car to you when its ready. Came in at 9am Thursday, left with a 4 yr. year old DTS and got my car back late Friday, good as new. I was under the 3yr B>B warranty. Imagine the cost if not covered by warranty?
  9. Interesting information, thanks! I bought the ADC camera and it helped a bit but not dramatically so,
  10. Just an interesting but boring piece of info. The camera being sold by ADC is the exact same camera sold by Camera Source. It even uses the same part number except Camera Source adds a CS- on the front. There were discussions a long time ago and I can't recall whether ADC is selling Camera Source cameras or Camera Source is selling ADC cameras. https://www.camerasource.com/products/2016-2018-sierra-silverado-hd-replacement-camera-cs-gmtrmod-16?variant=47619180101891&_pos=40&_fid=63889b968&_ss=c
  11. Sounds to me like normal fuel injectors firing off. Mine has been the same for over 5 years.
  12. For the transmission I just went with the TSB. Chevrolet TSB 21-NA-199.pdf
  13. Well, I would suggest phoning up Rough Country and making sure it's right for your truck. Or at least going through their website to check it's compatibility.
  14. Have you tried this option? ADC rear camera upgrade
  15. Yes, GM's recommendation is to not flash updates for anything, unless the vehicle has a problem that the update is listed as fixing (this is for any module, not just the infotainment system).
  16. I went with Borla Touring cat back exhaust. I thought about the ATAK but figured my neighbors might prefer a bit more quiet.
  17. The Amp power steps are great! I've had them installed for quite some time. I do, however, have to replace the cushioned bump stops so I don't get a metal clunk when they deploy.
  18. My truck didn't have a brake controller from factory so I had the dealer install this: Curt Spectrum trailer brake controller
  19. Hello everyone, I have a 2020 Silverado 1500 RST with the Max Tow package, and I'm trying to confirm whether this lift kit is compatible with my truck: https://www.amazon.ca/dp/B07XLDTT4N?ref=ppx_yo2ov_dt_b_fed_asin_title I’m scheduled to have it installed at a shop this Friday, but I’m starting to have some doubts about whether it’s the right kit for my truck. I’ve come across a few posts mentioning that certain lift kits may not work with the Max Tow package because of differences in the factory springs or suspension setup. Has anyone here installed this particular kit on a 2020 Silverado 1500 RST with the Max Tow package? I’d really appreciate any firsthand experience or advice on compatibility before I go ahead with the installation. Thanks in advance!
  20. Just did an oil change on Dizzy. It's first batch of R&P 5W30 and a shot of the new Valvoline Fuel system cleaner. It was the inkiest, stinkiest batch of oil I've pulled out of that motor.
  21. Depending on what vintage of Jeep you have, you may have a new enough one that its an open element filter and with little effort pretty easy to examine or if older its a canister and cut it open. It would be interesting to see what if anything shows up on the filter media. What blows me away is watching some of these videos where the person says they are on the 4th oil change with R&P and there are still all sorts of pieces that look like flakes of build up that broke off inside the engine along with smaller particles layering up in the lower part of the filter pleats and the person is saying it looks a lot better than the first filters did ... like holy hell ! LOL. I wish I could get my hands on HPL if I ever chose to try it out but that seems to be a no go here in Canada, I am only guessing that the product gets sucked up so quick in the states that they have no reason to even contemplate having dealers and shipping to another country and all the bs associated with that.
  22. Mama always said that if you’re gonna be dumb, you better be tough too.
  23. Why not run both, you ask? Well I am. R&P 5w30 plus a quart of HPL EC40 has been in my Jeep for around 1500 miles. I’m not really trying to solve any problems, no measurable consumption or issues. Just figured at over 100k, most of it probably on shelf oils save for my ownership period…might as well do a general cleanup. As I see it the products target two different areas. R&P seems to target pistons/ rings. The ester based HPL may be better at general varnish type cleanup. Will be back on Red Line for the next run but will pull a UOA on the cleanup cocktail and see how things are interacting.
  24. Yesterday
  25. It's perfect for me... Black A black 2027 Yukon on order
  1. Load more activity
