All Activity
This stream auto-updates
  1. Past hour
  2. Based on what I can tell, yes. As for updating it, its a mixed bag. Updates do fix a lot of issues, but occasionally can create some oddities. They do more good than harm though overall. Here's what the most current one does and a V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up V167 Most Notable Improvements: Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use. V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app. SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
  3. Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer. The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight. Most noticeable at slow speeds. Any insight is appreciated.
  4. We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
  5. Today
  6. We had a pretty big cars and coffee in Indy this past weekend. Pretty much anything and everything was there.
  7. Good looking Olds, and TRX! I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home. Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot. Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
  8. I know of 2 5.3L engines with AFM that run great. One now has 176,000 miles and the other has 235,000. Never opened up. Sound quiet. They have the same lifters with the pins as we do now. The 176,000 mile is my brother`s 2007 Avalanche and the other is a coworker`s 2010 Tahoe. I`m not going to say that these systems are as reliable as before cyl deac, cause they`re not. BUT, these engines came before the 0w20 "mandate". Hmm. Something to think about? Pins have better separation from the body and move better? Not all lifters that fail are deac lifters. Hmm. Rollers and needle bearings with better separation? Just thinking out loud.
  9. Had a 2011 - replaced the brake switch - that was the problem, for me.
  10. So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
  11. Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
  12. The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
  13. Question @diyer2 on this line if you please. Are you saying the shudder is the system turning on and off at the frequency of the shudder? Guess I'm asking if you are saying you have seen it do this with the bi-direction scan tool in graph mode? If so have you been able to discern the 'trigger'. Something is telling to cycle rapidly. My truck just started doing this recently. 197K on the clock. My response has been M5 anything under 55 mph. I treat it like a lugging stick shift. Gear down and let it spin a bit. Engauge M5, then tow mode and then M6 lets the trans stay in 5th but the AFM is active. Smooth like Skippy. My thought was that as a machine ages the friction gets lower and as the system is load based, the lower friction would allow it to turn on at ever lower rpm until it reaches the lugging point. And yes I am ignorant of any minimum rpm requirement for the system. If you know that would be useful information. As you know I run a Scan-Gauge II which allows me to watch the On/Off of the signal to the VLOM. While in the shudder mode I'm not seeing is cycle at that frequency or at all for that matter outside the triggers @newdude posted a few years back. Now is it possible that the refresh rate isn't fast enough to catch it? Maybe. It is why I asked my first question about graphing and trigging parameter. As we have observed from members here the failure point is all over the map miles wise as you note yourself in your opening post. That by itself begs a few questions like fellows that comment on these lifters failing even after the system has been disabled. Long after. https://www.enginelabs.com/news/tech-tips-replacing-ls-active-fuel-management-lifters-with-melling/ The Gen5 lifters operate the same as the LS versions. In fact they are the same lifter. https://www.enginelabs.com/tech-stories/sorting-out-gen-v-lt-lifter-failure-with-a-simple-valvetrain-fix/
  14. UPDATE 2: Steering wheel control backlights and control of the cluster can supposedly be achieved by adding a wire to pin 20 of the cluster and tapping it to pin 2 of the main clock spring harness. I'm going to give it a shot - will update
  15. GM Global A pickups 2019-2022 can do OTA programming for the radio. GM VIP (GM Global B) can do OTAs for almost every module on board. So a 2022.5 and newer pickup can do OTAs for recalls like the 2.7 fuel flow recall. EVs get OTAs that improve one pedal driving, radio issues, HVAC issues, updated battery management software, etc. So age of the vehicle/what GM electrical platform its on will alter what amount of updates can be pushed on OTAs.
  16. Thank You. So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery. This engine combination is very amazing. So far no issues and had not done a regen yet.
  17. I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out. I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
  18. Just changed mine at 35,115 miles. I carefully removed the gasket to get it out of the way. Then turned and twisted the pan just right and it slid right out. It can be done. It also went right back in. My pan very close to no clutch material in it. The magnets also had very little on them. The truck us used but not abused. Tow a 28.5 foot camper 5 or 6 times a year just under 6k loaded and a 3000 pound bass boat. Live in ohio not terribly hilly. Pretty happy how it went today.
  19. $4.19 or so for 87. $5.40-5.80 for diesel.
  20. From my above post, I got the whole assembly out. Had to use YouTube as there was one hidden bolt. What happened was GM wraps the little wires around a couple pins to hold the wires in place. The pins made the wire so tight that the bulb would only turn about 80 degrees. That last 10 was stopping the bulb from being able to be removed. Once I removed the wire from the pins the bulb came out no problem. Knowing that, wouldn't need to pull the whole assembly again as the wire can be pulled from the pins with the assembly in place. Thanks Jim
  21. Mobil and Gulf now $3.89, truck stop $3.86, Sunoco still $3.69. Up Up and away!
  22. Yesterday
  23. So, these updates are strictly for the radio? They don't update any of the truck's modules?
  24. Dexos is for engine oil. Not gear oils.
  25. That's about 4-5 build versions old if you have the 8 inch IOS or IOT radio. V155 is the number that tells you what version of software it has. Newest IOS/IOT radio software is V171 which was released June 2024. You'd have to pay out of pocket for the update at the dealer. TSB on the current software is 24-NA-108. MC-11004657-0001.pdf
  26. You'd be the first to make it happen if you tried it that I know of. You'd have to order a pair of option code DLF mirrors for a Chevy HD truck, and then attempt to swap all the components from those LTZ 1500 mirrors you bought on to the DLF HD mirror mount. If it would work.
  27. It's not on the dexos list. No need to pay GM just to be on the list. It is a great product and will serve you well.
  28. Is the AMS Oil Dexos certified? Just wondering as I would like to change both front and rear differential fluids shortly......
  1. Load more activity
