All Activity
This stream auto-updates
  1. Past hour
  2. Is the AMS Oil Dexos certified? Just wondering as I would like to change both front and rear differential fluids shortly......
  3. For anyone checking out the M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV, here’s an install video that gives you a closer look at how the roof-mounted setup comes together. It walks through the mounting process and shows how the curved 50" PRO fits along the roofline, which should be helpful if you’re considering the setup and want to see what the install involves. Hope this helps anyone thinking about adding the 50" PRO to their Hummer EV!
  4. Decided to check for updates for my 2021 Silverado 1500, and the system showed no updates available. When I checked the build number, it looks like it hasn't been updated since it was new. Does this look like I'm missing a ton of updates? Thanks
  5. For anyone considering the M&R Automotive 40" SLIM Light Bar setup for the 2022+ Chevrolet Silverado 1500, here’s an install video showing how the behind-the-grille setup comes together. It gives you a closer look at the mounting process and what’s involved in getting the 40" bar positioned and installed while keeping everything tucked behind the factory grille. Hope this helps anyone considering the setup or planning to tackle the install themselves!
  6. Today
  7. I can see them dropping the SLE trim line but the SLT trim?? I think that's a bad move, I know several acquaintances that always buy SLT trim, usually every 3-4 yrs. They would never consider an AT4 (older) and the Elevation is a cheap model in their eyes.
  8. I assume I'd be opening up pandora's box if I tried to source the early WT mirrors and tried to get the 2500 bases fitted to the rest of the 1500 mirrors...
  9. Get a Range AFM disabler or have someone with a tuner go in and turn off AFM. Simple fix. You should be lucky it didn't lunch the camshaft.
  10. 1500 mirrors will NOT fit HD. They do NOT share doors which means they don't share mirrors. There is only one small mirror for HD and it has nothing but heat and power glass. If you have cameras and blind spot, your only option is the factory equipped towing mirrors.
  11. $5.06 at our Kroger today
  12. I still kick myself for not buying your last truck when you had it for sale. I had two at the time so I passed, damit.
  13. I did some driving around the woodlands area and saw some 3.31 a gallon prices. Usually my local Kroger’s is the cheapest. It hasn’t always been here lately. I usually get the benefit of my Kroger card. I don’t add that in for this purpose.
  14. So resurrecting this thread... Is it possible to get the 1500 mirrors with power folding, blind spot and 360 view that have the "square" mounting stud pattern? Did not realize there was a difference and ordered '25 1500 High Country mirrors to mount on my '25 2500HD LT and came to the unfortunate discovery that the mounting studs have different patterns.
  15. Seeing the same thing here, the truck stop is usually a couple cents cheaper than everywhere else but they were higher than surrounding stations this am, will see if the others go up this afternoon $3.76 truck stop, $3.74 Gulf, Sunoco still $3.69 but the tanker was there this am so that may change, Mobil $3.84
  16. Gasbuddy lists Costco in Mansfield as the cheapest in Texas at 2.93 for regular but also more than one place around that 3.00 level in Houston. I am guessing that is probably some of the lowest fuel prices in the states ?
  17. Resurrecting this thread. I was wondering if anyone has information about the differences between mounting bolt patterns for mirrors and how to understand what mirrors have what pattern.... I have a 2025 2500HD LT and want to swap my stock power folding, blind spot and 360 view mirrors with 1500 mirrors with the same features. I ordered a 2025 1500 High Country mirror but came to find that they have different mounting patterns as seen in this picture. @modernmetal did you have issues with the mounting pattern?
  18. 3.51 Kroger’s in Montgomery Tx. Surprisingly they’re not the cheapest. That is unusual.
  19. GMT900 6.2 Trucks didnt have AFM, which was nice.
  20. If it won't pull it, then it won't pull it. You'd have to use one of those sites where you can buy a reprint.
  21. I never liked the choppiness of AFM (or DFM) in my '15 and '20 Silverados and IMO it's worth disabling just for the driving experience alone. I wonder what the actual failure rate of AFM/DFM is.
  22. 186K miles on my 2020 8-spd. Butter smooth shifts.
  23. Im unable to pull up the sticker for my 21 Sierra. It worked fine for my 19 Silverado... Can someone pull the sticker for me Please? 3GTU9FET6MG179370
  24. I have a 2" lift, so the equivalent of the factory trail boss height, and it has been on the truck for approximately 165,000 miles. I don't believe the lift to have had any significant adverse affects on the ball joint. The socket was dry of grease and warbled out over extended use, but the ball/bolt itself wasn't broken, stripped, bent, or anything. It just pulled out when the UCA socket bore wore enough for the ball to slip out.
  25. It use to be pretty common for me to add a Super Charger. The only way I would chance it today would be dealer install with a warranty. I only have experience with Ford. They are doing well so far.
  1. Load more activity
