Best Fuel Economy Tune
I'm looking for a tune that will give me the absolute best fuel economy out of my 2007 Silverado 5.3L AFM 4x2.
Is there a tune that will allow the AFM to stay on longer?
do you have hptuners? you can change the engagement points of the afm. i get 25mpg on the freeway with a tune and a much lighter right foot in my 07 crewcab
How much was hptuners? is this a handheld or a chip?
Neither, it's software you load onto your laptop. It runs about $500 for std version, $750 for "Pro" version. Most tuners HIGHLY recommend getting the "Pro" version.
i really dont know why that is. for a tuning shop, sure, but the pro doesnt give you any more tuning control than the basic, just a little easier datalogging capability. not necessary at all, dont bother.
For mileage, I've been hearing good things about the Hypertech Econ unit. But I haven't used it personally. Otherwise it's going to be rather difficult to find out "which one is best for mileage" since it mostly depends on the driver and vehicle. Of course, that applies for tuned and stock as well.
truth be told, your best gas mileage mod is a DIC so that you can see when you are in v8 mode or v4 mode. similarly, you need the driver mod. keep your foot out of it...hardest thing to learn, but its what you need
One thing I really don't understand is people that are willing to spend a few hundred dollars to gain a little bit of fuel economy. Unless you're driving an insane amount of miles, it's going to take a lot more time than it's worth to make back that money. $300 can buy a bunch of gas.
Just my $.02
its worked well for me. with the purchase of HPTuners, you get 4 sets of tunes. i tuned my truck and charged 3 people $100 each to tune their vehicles for power/mileage. the tuner ended up costing me just over $100 and i saw an improvement of nearly 5mpg or 25% on the freeway. with $100 fillups, a 25% improvement will pay for itself in nearly no time
I'm not following. our 07 Tahoe we traded off had a mode on the instrument digital read out that would tell you when you were in V4 or V8 mode.?
    DaleB
    DaleB
  • Who's Online   5 Members, 0 Anonymous, 1,381 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
