4x4 Help For A Newbie
I have an 88 2500 4X4 with a 5 speed and the floor 4X4 shifter. i can get it into 4 wheel, and the reducer for 4 low works but the front wheels dont engage. i have seen a few places on here that the 4 wheel drive actuator is usually the problem but i have not seen any with the same symptoms i have. Should i start with the actuator? THANKS
By all means covert it to the newer style actuator that is available,I had a 1994 with the same issue,converted it to the newer type actuator kit comes with a new actuator and harness,I believe there was GM TSB to addrerss this concern.
Here is what you need there is a post if you look down.
<H2 align=left>88-UP C/K ACTUATOR UPGRADE</H2>
VEHICLE SERVICED: 1994 CHEVROLET FULL SIZE BLAZER (2 DOOR)
PURPOSE: IMPROVE AXLE CONNECT ENGAGEMENT TIME AND
COMPONENT RELIABILITY.
SYMTOMS: NO FRONT DRIVE AXLE ENGAEMENT WHEN SHIFTED
INTO 4X4.
Obtain the following GM part numbers:
(1) 26060073 Actuator
(1) 88959465 Harness/Spacer Kit
so if i go with the stock actuator, it just screws in and clips on the other end... the newer version also screws in but i need a new wiring harness, and posi lok is a whole different ball game and is more expensive.
what is the advantage on the newer version?
Okay, so i replaced the actuator and still no luck... the drive shaft now spins when its engaged so i think the actuator may have been part of it, but the wheels still dont go.
any other ideas?
Did you do the diagnosis in the link I posted?
yes, and the actuator only moved a little.. not as much as the one on my grandpa's truck so i thought that was it.. and im sure it needed replacing anyway but there is some other problem too.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
