Noise When Ac Or Heat Is On?
I had a 95 2dr yukon and now a 98 z71. Both of which make a light clicking noise when the heat or air is turned on. It sounds like there is a leaf in the dash? but on both vehicles? is this common and how can you fix it.
It's possible something could have fallen into the ducts. Do you keep things on the dash over the defrost vents? Could also mean you have a blower motor going out. The bearings go bad and will make noises.
    bellssn690
    bellssn690
  • Who's Online   0 Members, 0 Anonymous, 815 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
