1989 V1500 ball joint replacement
Has anyone replaced ball joints on '89 V1500 or similar 4x4? It's a leaf spring, solid front axle. I'd just like to know what's involved.
Thanks!
you will need to disassemble the hub assemblies so you'll need special sockets for those. also the upper ball joint will havea little camber sleeve that takes a special tool. if youve done them before it'll take under an hour per side start to finish. if you're a first timer. find an old fart to show you how to disassemble the hubs/wheel bearings lol or get a repair manual so you have step by step which clip and which lock rings to take out
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 401 Guests (See full list)
