Got steel Wheels?
Tire Slowly Goes Flat and/or Excessive Wheel Vibration (Replace Wheels with New Heavy Duty Rim Version) #03-03-10-001 - (01/07/2003)
1999-2003 Chevrolet Silverado 1500 Series Pickup Models
1999-2003 GMC Sierra 1500 Series Pickup Models
with 6-Bolt, 16 X 6.5 Full Face Steel Wheel (Base and RPO PY2)
Important
Implementation of this service bulletin by "GM of Canada" dealers requires prior District Service Manager approval.
Condition
Some customers may comment on a tire that slowly goes flat and/or excessive wheel vibration. This condition is more apparent on vehicles in which customer usage typically involves frequent severe conditions such as:
High load (at or above gross vehicle weight)
Rough road/off road usage
Fleet/Commercial usage
Cause
The wheel may experience a crack or split in the outboard bead seat weld area. A weld attaches the rim and disc together on full-face wheels in this area. To identify this wheel, it is offered in a silver painted version , P/N 9593915, code "TZA" and a chrome-clad version, P/N 9593150, code "RSC" (these codes are stamped into the wheel's disc near the bolt holes).
Correction
A new heavy-duty rim version of these wheels has been released for service. The new heavy-duty painted wheel is P/N 9595245, code "FFU" used as a road wheel and spare. The new heavy-duty chrome clad version is P/N 9595306, code "FFW" used as a road wheel only (these codes are stamped into the inboard rim flange balance weight area, and are also on a sticker near the bolt holes). If a condition of a crack or split as described above occurs, all (5) five of the original wheels on the vehicle should be replaced with the new heavy-duty wheels.
Parts Information
Part Number
Description
9595245
Wheel Asm. (Painted)
9595306
Wheel Asm. (Chrome Clad)
Parts are expected to be available January 13, 2003 from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E0420
Wheel - Replace
0.5  hr
Add
To Replace Each Additional
0.3 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.  WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 635 Guests (See full list)
