2006 4.3 Random misfires and stalling at idle
SoCalChris
I've got a 2006 Silverado WT with the 4.3 V6, and around 155,000 miles. Today, it started misfiring. It doesn't seem to matter what load the engine is under, it's done it at highway speed and on local streets. When stopped at a signal, it died completely a few times today. It didn't have any problems restarting.
About 6 months ago I changed all of the spark plugs and wires, and haven't had any trouble until today.
Where should I begin looking? Vacuum leak? Coil? Fuel issue?
Any suggestions would be greatly appreciated.
Thanks
Mine did it at idle. I would do plus and wires again (my issue) with GM/Delco parts. Then work your way to a fueling issue by checking fuel pressue. Then check out cam sensor or crank sensor if your issue has not been resolved
Sent from my Samsung Galaxy S4 using Tapatalk 4
On the way in to work today, it made it about a mile and just died completely. It cranks, but won't catch at all.
I'm leaning towards the crankshaft or camshaft position sensor, but I'm going to test the fuel pressure this afternoon as well. It's been sitting for a while now, and had some time to cool off. It turned over, although it still wouldn't totally start. I'm going to let it cool completely, and then try again. Several years ago I had a Safari that one of the sensors went out on, and it behaved exactly like this. It would die as soon as the engine warmed up, but ran OK cool.
On Friday, I checked the fuel pressure, and it was ok.
Then I tested and there was no spark at all, so I replaced the coil. It ran great, and since then I've put about 300 miles on it. Within the last 100 miles, it's starting missing again at all speeds, and randomly dying while idling. It didn't leave me stranded this time, but I have no doubt that it will pretty soon if I keep driving it.
Does this sound like the ignition control module is going out? Or distributor? Something else?
Thanks again for the help.
I have very little knowledge of the v6. I just know basics and told you common issues
I just wanted to post a follow up for anyone else who has this issue.
I took out the ignition control module, and had it tested at two different auto parts stores, it tested bad at both of them. I replaced it, and had the same problem.
I then noticed that if the truck was running, and I bumped the wires supplying power to the coil, the truck would stutter and die like it had randomly been doing. Bingo.
I replaced the wiring harnes bringing power to the coil, and haven't had a problem since. I've put around 500 miles on since then, and the truck is running like new.
Thanks again for the suggestions.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,211 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
