Front Suspension and wide tires
I need soem input from those of you who know more than me about front suspensions...which won't take much. ???
I have 60s on the front of my 93 GMS SWB pickup.
It came with 75s. Big difference.
I had to recently replace my idler and stedman arms which really should not have worn out and seem to have alignment and issues of my front wheels "skipping" when I cut the wheel hard. They also have a tendency to slide easily when I cut the wheel hard. :jester:
Is this because the wide tires are throwing off my suspension geometry?
If so, what are the widest tires I would be safe with? ???
Hmm, I had 275/60/15's on the front and back of my '91 2wd Silverado without any problems at all.  The truck had a little over 89,000 miles on it when it was totaled, and I had those size tires on it for about 60-65,000 miles of that.  I only had to trim a piece of that rubber wheel well liner on the drivers side because it rubbed when the wheel was turned all the way.
I had no suspension problems at all during that time.  The truck handled great with those tires.  :jester:
interesting...you had the EXACT size tires I have on mine...but I got about 107K on my 93 ???  :jester:
:crackup:
"SoDam Insane" should be caught and stoned...by his fellow countrymen.
the 75 or 60 number you are referring to is the sidewall height as a percentage of the treadwidth which is the first and larger number 275/75 is no wider than a 275/60.  the /60 is just a lower profile tire.
Either way it sounds more like an alignment problem than anything else.
I think he's refering to the 75's as 235/75/15, which was the stock size tires on the 2wd.  The 275/60/15 were shorter and wider than the 235's.  The 275's were the same size that came on the 454SS's.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 802 Guests (See full list)
