Hangover cures/prevention?
elboberino
Not that I am going to have one but in the morning but what do the folks of the GM-Trucks forum use as a hangover cure or prevention? I like to take 2 advil and drink 2 glasses of water before I go to bed or pass out (if I can physically possible). What does everyoine else do??
Hair of the dog- WAKE UP & DRINK! :chevy: J/K :D
I dont drink nearly as much as I used to (wife & 2 kids now) but your suggestion used to work for me- 2-4 asprin & all the water I could drink + chew about 8 papaya tablets- helps settle your stomach. :eek:
Water, water, water, water, water, and ummm....water.
Drink so much of it, that you are going to puke from it before you go to bed.
You may have to get up and pee 92 times that night, but your head will not hurt.
Doesn't hurt to drink about a pitcher of it before you start drinking either.
The best prevention....hmmmm....DON"T DRINK!!
I know...that won't work will it? I used to drink German beer. No sulfides, mean no headache in the morning. AH YEAH! :chevy:
well sometimes you have to drink..... :D
Seems like water is the way to go. I'll keep that in mind for the morning since I have put back a little more than I normally do. But get this, I can still type!!! Must be from all the years of sitting in front of a computer and typing on instant messenger (geeez, I am a big dork!) :eek:
Cheers! :D
Hair of the dog- WAKE UP & DRINK!  J/K
That's hard to do when you have class the next morning!
:cheers:
That's pretty good...i couldn't type to save my life when I was drunk. Although...that doesn't really say too much I can't type too good sober....hehehehe.
it happens to the best of us......
the count is 2 bottles of red wine (the only alcohol in the apartment, complements of my folks) right now.....probably not gonna start a third
Red wine?!?! Yuck! You are asking for a headache. There is a known extract/enzyme in red wine that causes headaches. Have fun.............. :chevy:
well it's 1:20 here...I'll let you know what I feel like in the mornin....I've popped 2 advil and drank lots of water
I hope my liver can stand all this torture
Red wine?!?!  Yuck!  You are asking for a headache.  There is a known extract/enzyme in red wine that causes headaches.  Have fun.............. :D
:chevy: bowtie
I don't think water will help a red wine hangover. They are worse than tequilla hangovers in my opinion.
Good luck with class tomorrow. :eek:
I agree lots of water and asprin. Booze dries you out and swells your brain. :chevy::D
Ass faar as typingg whilst drunk. I have ent notice!d any pwroblemss. :eek::D
well it's about 9:20 in the morning and the only thing I notice is a bad taste in my mouth. No headache, no stomache ache and definitely no puke :D . Looks like I beat alochol again. 2 advil and water was the key, but hey, i think menudo would have been a good alternative. Well, I gotta shower now and brush my teeth, my breath is really bad! Cheers :chevy:
    Gkistler
    Gkistler
  • Who's Online   1 Member, 0 Anonymous, 881 Guests (See full list)
