Home Based Job
Delaware
I work from home. Whatdya wanna know? It's toughest the first 3 months you do it, then you get a schedule down and it's just like work. I am pretty lucky though, the company I work for is pretty leinient(sp) on my hours...as long as I get my crap done and work 40 hours in a week, I'm good to go, they like me to try and be around the house during business hours though. Tell ya the truth though, I get most of my work done between 8pm and 2am.....
BTW....I do Application programming, a lot of database stuff, and a lot of software testing, I try to break sh*t, and then fix it.
can't beat the commute either.
You must be slackin off then cause most all of our software has bugs and errors and never works right, so you call the IT people and "yes we know about that problem heres 10 longer steps you now have to do to correct/ go around the problem". BTW I work for the gov so everything they touch turns to shi....
Heh, I get plenty of SPAM about "Becoming a millionaire by working at home" and that type of shizzle ... I can give em your email address if ya want! :thumbs:
Seriously though, I think you've got the right idea. I'm a programmer as well and soooo much of my job could be done from home. Granted it's nice to be able to walk down the hall to someone else's cube if ya have a question, but on the flipside, if I were at home they couldn't walk down the hall and bug me with questions when I'm in the middle of something! :thumbs:
I do insurance inspections for commercial business property. I'm based out of my home, but I have to travel a fair amount of the time. Basically anywhere from 25-75% of my work week is spent away from home, the rest of it is in my home office writing reports, scheduling visits, etc.
It's very nice to work at home/have flexible hours, but I still have to get my work done. The downisde is that when I'm not working, everything is still right there, lurking behind that door.
LOL....if I didn't make software with bugs in it, I would be out of a job.....there would be nothing to work on once it was released. The point about not having people be able to bug you is very true. It kinda sucks sometimes because if I have a question I can't walk down the hall, but I just use IM or email which is almost as good.
I know I get more work done in 3 hours of working at home, then I ever would working 8 in an office. There are just to many d**n distractions....that's why I do most of my work at night..everyone is asleep and there's nothing on TV, to get my ADHD going....LOL
One of my co-workers works from his home a couple states away in the next time zone. He connects to our servers via a VPN and runs production jobs starting at 5:00 AM his time. This allows him to update the rest of the staff on how things are running when we arrive at work an hour later, 7:00 AM our time. (We process and warehouse date from many different sources. Sometimes (often) these sources forget what they're doing.) His day is usually not a regular 8 hours. Sometimes he's done by 10:00 AM. Sometimes people at the office have to fix things and he has to take some time off in the middle of the day and start again at 3:00 PM. He gets paid only for the hours he works. He's an expert at the legacy operating system he works on (Honeywell Bull) and is in constant communication with co-workers via instant messenger.
Why do you want to work from home? Some folks really miss the social aspect of being at the office. Then there's the "out of sight, out of mind" attitude of some management. (Our management marked the above person for down-sizing until someone convinced them that no-one else could do his job.) I found that working 1 day a week at home and the rest in the office worked well for me. Without the constant interruptions, I could spend that day working on what was really important, not just urgent.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,239 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
