99 Z71 with factory trailer package
My Brother in law will be towing a 28ft. camper this Thursday, his 99 Z71 came with factory trailer package, with a harness in the glove box for the electric brakes. From doing a search I've found the place to connect the harness is next to the e-brake pedal on the top row 2nd slot from the left. I know where all that is, but my question deals with what I do after that. Is it just a matter of connecting all the wires on the harness to an electric brake controller? It already has the 7 round connector in the rear. Will he need another adapter to connect to the camper? Like a 7 round to "whatever" the camper is? Is there anything else that needs to be hooked up, or is everything already connected except for the harness and controller? Do I have to add any fuses to complete the circuit? Just want to make sure I don't mess up his truck or cause him to get hurt because I install it wrong. Thanks, Chris
The RV should plug in to the factory installed plug. Once you hook up the brake controller to the harness you should be good to go. Don't forget to install the fuse that comes with the harness.
You may have to put a "Maxi" fuse in the electrical center under the hood if it's not already there... It goes in Stud 1 or Stud 2. (I can't remember right now...)
Also, the wires on the pigtail that plugs into the box behind the E-Brake, most likely won't match color for color with your controller. They should be labeled and you can match them from the labels.
Here's a bad picture of the way mine was wired... just note the colors aren't matched between the controller and the harness.
Here is a pic of my electrical center under my hood... I think the Maxi Fuse was the green one (30 AMP?)...
    bellssn690
    bellssn690
  • Who's Online   0 Members, 0 Anonymous, 815 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
