2" Rear Drop on Ext. Cab Pinion Shims
Have any other guys had to install 2 degree or 4 degree pinion shims after installing 2" shackles on their ext. cab 2wd NBS trucks? My truck is shaking @ 65-70 mph and it seems to be getting progressive worse, the more I drive the truck. I think I need a 2 degree shim installed with the fat part of the shim rearward, since the 2" shackles will tilt the front of the pinion down. Comments? All advice appreciated!!
Way ahead of you... It has been into 2 dealerships and both said the u-joints and carrier bearing is fine.
Didn't have to on my '03. I had just shackles on it for about 8 months with no problems. Now I've got a 2/4 kit and still no problems. I've heard every truck is different though. Some need them, some don't.
My truck has 160km (or 100miles) on it and the drive shaft splines are starting to get a little loose. I think that has amplified the vibration problem. I am having 2 degree shims installed this week and hopefully that fixes the problem.
  • 8 months later...
I dropped my 'o5 crew cab 2" and needed the pinion shim kit.  Took the slight vibration away IMMEDIATELY!!!
May be a dumb question, but I have had 2" shackles on mine for a while and have had this vibration badly. Where does the pinion shim kit go and where do you get it. Any info would be appreciated.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 216 Guests (See full list)
